I need help now!!
Old May 12, 2003 | 10:55 PM
Havokmkr's Avatar
Default I need help now!!
I just helped a friend of mine install indiglo guages in his 99 accord sedan. It's automatic with a 4 cylinder 2.2L vtec. We installed the guages and everything looked fine. Well now the car won't shift from park. The check engine light is on and the brake lamp is on. He has to go to court in like 5 hours and we have to fix it. I'm begging anyone and everyone to help me on this.
Old May 12, 2003 | 11:08 PM
civgra's Avatar
Default Re: I need help now!! (Havokmkr)
check to see if the brake lights work? if they dont check for power at the brake switch near the brake pedal! or check the fuses! if the brake lights work check for power coming into the shifter soleniod! all in al there should be a little slot that will let you shift the car out of gear!!
Old May 12, 2003 | 11:09 PM
Havokmkr's Avatar
Default Re: I need help now!! (civgra)
where is the shifter solenoid?
Old May 12, 2003 | 11:21 PM
civgrra's Avatar
shifter soleniod in under the center console. near the shift lever! will the brake lights come on when the brake is apllied?
Old May 13, 2003 | 03:24 AM
b19coupe's Avatar
There is a by-pass mechanism for the shift interlock. Just put the key in the slot by the shifter and put the car in neutral. Then start the car and drive it. Then, when you have time, find out what you broke. A blown brake light fuse could cause your problem.
redsidriver
Nov 28, 2011 06:08 AM
Entaka
Jun 14, 2008 10:00 PM
mattyk85
Aug 20, 2007 05:05 PM
puppetmstr80
Aug 26, 2005 11:43 PM
JMD
Mar 3, 2005 02:56 PM
