Cometic headgasket b18a, .030? .035?
Old May 12, 2003 | 02:30 PM
Flexmyrex's Avatar
Default Cometic headgasket b18a, .030? .035?
i will be replacing my timing belt, i thought it would be a good idea to replace the headgasket as well. im going with a cometic hg, afterhourzracing has them on the site but which one should i get .030? .03+ etc i want to keep the compression ratio at oem
should i replace the head studs w arp or just go w oem ?
Old May 12, 2003 | 02:45 PM
Spade's Avatar
Default Re: Cometic headgasket b18a, .030? .035? (flexmyREX)
Just get a OEM gasket.
Old May 12, 2003 | 02:46 PM
K20  EG's Avatar
the .030 is o.e.m thickness
i got mine from http://www.nipponpower.com on the website it says $99.95 for the gasket
if you call them directly it only cost $79.95...hmm...i know it sounds funny ...try and call them to order it if you havent already
peace
Old May 12, 2003 | 02:53 PM
.RJ's Avatar
.RJ
FYI, mugen gaskets do not work well on B18A motors...
I have one on my car, and the dowell pin holes in the gasket were too small (dremeled it) and it appears to be seeping oil slightly on the front of the motor.
RJ
Old May 12, 2003 | 07:21 PM
Flexmyrex's Avatar
Default Re: Cometic headgasket b18a, .030? .035? (.RJ)
i can get the cometic for 75-80 bux, anyone know how much one would cost from acura dealership?
Modified by flexmyREX at 5:51 AM 5/13/2003
Old May 12, 2003 | 10:26 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flexmyREX &raquo;</TD></TR><TR><TD CLASS="quote">i can get the cometic for 75-80 bux, anyone know how much one would cost from acura dealership?
Modified by flexmyREX at 5:51 AM 5/13/2003</TD></TR></TABLE>
Should be 60 or so.
Stock is best whenever possible.
Old May 13, 2003 | 07:37 AM
.RJ's Avatar
.RJ
Default Re: Cometic headgasket b18a, .030? .035? (sgT)
OEM -
Mugen -
Old May 13, 2003 | 07:44 AM
AllMotorMadness's Avatar
Default Re: Cometic headgasket b18a, .030? .035? (B20---Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20---Vtec &raquo;</TD></TR><TR><TD CLASS="quote">the .030 is o.e.m thickness </TD></TR></TABLE>
I thought stock O.E.M. thickness was .027, somebody correct me if I'm wrong.
Old May 13, 2003 | 10:53 AM
sgT's Avatar
sgT
Default Re: Cometic headgasket b18a, .030? .035? (AllMotorMadness)
.029"
HPfreak
Sep 23, 2011 04:53 PM
EK_EG_DC
Feb 25, 2009 08:39 PM
Toy Civic
Jan 24, 2007 02:04 PM
2chron4u
May 16, 2004 08:10 PM
D16A6Turbo
Dec 1, 2002 06:16 PM
