B18C Vtec is not engaging and CHECK ENGINE light is on
Old May 12, 2003 | 06:20 PM
mz3bo's Avatar
Default B18C Vtec is not engaging and CHECK ENGINE light is on
Hi, today was rainy and this happened for the first time. When the car was about to hit VTEC point in 3rd, the check engine light goes on and the VTEC just never engaged. This problem does not happend in 1st or 2nd gear, just the 3-4-5... Someone know what's wrong. The engine is a USDM b18C1 with p72 ECU in a 97 Coupe. Also, can you tell me where the disgnistic port is located originally.
Thanks
Bo
Old May 12, 2003 | 08:11 PM
mz3bo's Avatar
Default Re: B18C Vtec is not engaging and CHECK ENGINE light is on (mz3bo)
Someone ????
Old May 12, 2003 | 08:23 PM
MikeSarr_GSR's Avatar
diagnostic port for the ecu should be the blue connector, however if you dont have it in your car due to a swap, you can find the connection on the wiring harness on the GSR ECU here:
http://www.hondata.com/images/gsrwiring1.gif
http://www.hondata.com/images/gsrwiring2.gif
Old May 12, 2003 | 11:07 PM
GS-R EK's Avatar
do you have a vafc? i had the same prob and a wire was confused, i got a vtec ops code. Check it out
Old May 12, 2003 | 11:12 PM
civgra's Avatar
Default Re: (GS-R EK)
check if your vss sensor is working? is youre speedometer working?
Old May 13, 2003 | 05:59 AM
mz3bo's Avatar
The speedo is running great, nothing wrong, just it's throwing a cel code and I can't find the damn blue connector due to the swap...
Old May 13, 2003 | 07:44 AM
Hondasaurs's Avatar
We need to know what CEL codes your getting. Post them and then we can come up witha suggestion that may help your problem.
Old May 13, 2003 | 09:47 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mz3bo &raquo;</TD></TR><TR><TD CLASS="quote">Hi, today was rainy and this happened for the first time. When the car was about to hit VTEC point in 3rd, the check engine light goes on and the VTEC just never engaged. This problem does not happend in 1st or 2nd gear, just the 3-4-5... Someone know what's wrong. The engine is a USDM b18C1 with p72 ECU in a 97 Coupe. Also, can you tell me where the disgnistic port is located originally.
Thanks
Bo
The service connector is probably lodged way up in your dash, but it should be located in the passender side area right up, under the dash. Use a flashlight and look for a GREEN rubber block.
There's 2 plugs that are inside of that green plug, pull out the smaller plug (either a blue or grey color) and jump it while your car is on w/check engine light on too. You can use a paperclip to jump the service connector, which will trigger the check engine light to blink and you'll get your MIL codes.
I'd show you some pics, but it seems my web server is down (damn pos).
Check out C-Speeds tech page on this subject:
http://www.c-speedracing.com/faq/06.php
Old May 13, 2003 | 09:57 AM
mz3bo's Avatar
Default Re: B18C Vtec is not engaging and CHECK ENGINE light is on (Katman)
Hi, I have a 3 short flash... it is Manifold Absolute Pressure.... What can it be...
Thanks
Old May 13, 2003 | 10:00 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mz3bo &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I have a 3 short flash... it is Manifold Absolute Pressure.... What can it be...
Thanks
uh ok..
is your MAP sensor hooked up? its the sensor thats on top of your throttlebody.
Having the MAP not hooked up will make your car run like total **** and your gas mileage should noticeably be reallly really shitty as well.
perhaps you have the MAP and TPS plugs mixed up, since they both use the same style of plug. check to see if you do..
killakoupe
May 8, 2007 07:43 PM
mazEK
11
Jan 11, 2007 06:29 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
grlstockb18c1
Nov 3, 2004 07:07 PM
brian2903
Dec 11, 2003 07:20 PM
