p28 ecu with b16a2??
Old May 13, 2003 | 05:08 PM
blazin99si's Avatar
Default p28 ecu with b16a2??
Need some help here people.....A friend of mine purchased a 93 Civic with a b16a2 along with I/H/E running on a Turbo OBD1 GSR ecu (Don't ask me thats how its labeled) Anyhow its running really rich and I was wondering since it already has an OBD1 ecu could a chipped p28 work with it if not better?? Anyway I could find out b4 purchasing a P28??
Old May 13, 2003 | 05:41 PM
eg6ajk's Avatar
Default Re: p28 ecu with b16a2?? (blazin99si)
yes a chipped P28 with a mild program should be much better then what he has (at least from the description you gave), check my sig . or if the P72 is socketed he can simply just buy chips (check sig again)
Old May 13, 2003 | 05:52 PM
dfoxengr's Avatar
Default Re: p28 ecu with b16a2?? (eg6ajk)
yes, will work better in fact
Old May 13, 2003 | 06:03 PM
blazin99si's Avatar
Default Re: p28 ecu with b16a2?? (hybridvteceg)
do you know if it will be a plug n' play??
Old May 13, 2003 | 06:08 PM
dfoxengr's Avatar
if it was plugging into the gsr obd1 ecu, and the motor is obd1 then yes of course
the_wholesaler
Apr 8, 2014 11:26 AM
jayWknight
Apr 20, 2012 06:03 AM
Mhollaek9
Jun 23, 2007 07:21 PM
aF
Jan 29, 2006 08:39 PM
