thermal HEADER WRAP??
Old May 13, 2003 | 08:09 PM
BURT REYNOLDS's Avatar
Default thermal HEADER WRAP??
i just got a sohc DC header for 40$'s off of my buddy..i was thinking about wrapping it up in some thermal wrap...any recommendations of what brand to get and where to purchase it?? also installing technique that works best...
Old May 15, 2003 | 12:41 AM
this cant be rare
Old May 15, 2003 | 06:05 AM
RCautoworks's Avatar
I asked a question awhile back on header wrap, and I found it causes more problems then its worth. If you don't wrap them right moisture can get in and cause rust ( if its ceramic ) and it also traps in heat and causes premature wear on the header.
Old May 15, 2003 | 08:46 AM
Stew Pidasso's Avatar
Default Re: (90blackcrx)
I wrapped my DC header and will continue to wrap headers. The underhood temps are much lower giving you cooler more dense intake charges. I used a wrap from DEI which I got a summit racing. 1" for the primaries and 2" for the secondaries...
Get the silicone spray, also from DEI, to coat the wrap to prevent moisture from becoming trapped underneath it. Use regular pipe clamps and not those stupid dei ones that don't work anyway.
http://store.summitracing.com/...10110
Old May 15, 2003 | 08:53 AM
Default Re: (Stew Pidasso)
BTW, mine looks crappy. It can look much better.
This one is not mine...
You can read some more in this thread...
https://honda-tech.com/zerothread?id=324341
Old May 15, 2003 | 02:07 PM
QCKGSR's Avatar
Default Re:
thermo tech
Old May 16, 2003 | 12:57 AM
Default Re: Re: (QCKGSR)
cheers
Old May 16, 2003 | 05:38 AM
94CivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote"> If you don't wrap them right moisture can get in and cause rust ( if its ceramic ) and it also traps in heat and causes premature wear on the header. </TD></TR></TABLE>
I know this can be a problem with mild steel headers, but I think if you're wrapping stainless, you're ok. Anybody can confirm this?
Old May 16, 2003 | 09:06 AM
StyleTEG's Avatar
Default Re: (94CivicSi)
They have been known to crack the headers as well. The only headers that would be worth doing it to would be cast iron ones like the oem JDM 4-1.
Old May 16, 2003 | 09:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
I know this can be a problem with mild steel headers, but I think if you're wrapping stainless, you're ok. Anybody can confirm this? </TD></TR></TABLE>
Yes you are right, but it still traps in the heat and that causes problems to over time.
naterocks21
Mar 8, 2011 09:21 PM
ZenDynasty
12
May 31, 2004 02:18 PM
bowhunter
May 5, 2003 09:25 AM
soopafly828
Apr 30, 2003 03:48 PM
5-SpeedFreak
18
Jan 25, 2002 09:44 AM
