b20 crank in ls block
Old May 13, 2003 | 04:22 PM
untitled's Avatar
Default b20 crank in ls block
can it be done easily? what needs done? what rods?pistons? what displacment will it yield if the block was bored to 1mm over stock with a first gen b16 head?
Old May 13, 2003 | 05:30 PM
notstock93's Avatar
Default Re: b20 crank in ls block (88crx91integra)
The CRV (B20b) crank is the same as an LS crank. The 2.0l displacement comes from boring the LS block to 84mm instead of 81
Old May 13, 2003 | 05:54 PM
dfoxengr's Avatar
al internals except sleeves and pistons between b20b/z and b18b are the exact same honda part #s
Old May 13, 2003 | 08:19 PM
untitled's Avatar
Default Re: b20 crank in ls block (hybridvteceg)
so that explains the b20's sleeve brittleness? can i safely bore the ls block to 84mm and run boost?(8-14psi)
Old May 13, 2003 | 11:05 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">so that explains the b20's sleeve brittleness? can i safely bore the ls block to 84mm and run boost?(8-14psi)</TD></TR></TABLE>
all in the tuning my friend. b20 sleeves aren't glass, but they are weaker
mike
Old May 14, 2003 | 12:13 AM
Kataku2K3's Avatar
Only sleeving it... NO way on stock sleeves... Wouldn't even try it for all motor... Send it out to GE if you are looking into sleeving As everyone as else has said internally the only difference between the B18A/B and B20B/Z are the pistons and bore... Both have the 89mm crank and PR4 (5.394in) rods... Good Luck
Old May 14, 2003 | 07:25 AM
untitled's Avatar
Default Re: b20 crank in ls block (Kataku2K3)
so then b18a blocks arent the same as b20's since the ls sleeves cant be bores to 84mm like the b20's. the b20 block's sl;eeves are different then the b18a.
Old May 14, 2003 | 07:51 AM
Kataku2K3's Avatar
That's it, the B18A/B and B20B/Z are made from the same cast but are machined with different sleeves from the factory. People say that the B20's sleeves are weak and they are compared to other factory sleeves but out of all the CRVTEC's i've seen/built there's never been a problem with them cracking... Most of my friend's have been running their's for a lil over a year now, (they all drive pretty relaxed on the street, then race every weekend during racing season) All have a static compression ranging from 11.5-12.5:1 and rev anywhere from 8400-9000rpm+ Get a B20 and you'll have a good start if you want a inexpensive 2.0L motor, if you got the money sleeve it... Just my $0.02
rdssk8rcs1
Mar 30, 2009 09:35 AM
raidacaipo
10
Oct 7, 2008 12:46 PM
Topdawgg
Mar 27, 2007 10:24 AM
No
May 1, 2005 06:45 AM
Boostless97Lude
Nov 20, 2002 09:11 PM
