is this my IAC valve?
Old May 12, 2003 | 12:25 PM
awps's Avatar
Default is this my IAC valve?
i have a 97 gsr, is this the iac valve?
Old May 12, 2003 | 12:26 PM
Spade's Avatar
Default Re: is this my IAC valve? (awps)
Doesn't look like it to me.
Typically they are on the TB of GSR's
Old May 12, 2003 | 12:27 PM
awps's Avatar
Default Re: is this my IAC valve? (Spade)
what the hell is that then? its not in my repair manual i have for the car.
Old May 12, 2003 | 01:08 PM
metal-x's Avatar
check out this site
http://tiiite.ghettoracer.com/tech/sk2manifold/
Old May 12, 2003 | 05:04 PM
B00ST2nR's Avatar
Default Re: is this my IAC valve? (metal-x)
hmm... looks like the Evap Sensor
Old May 12, 2003 | 05:33 PM
B-Tuning.com's Avatar
Default Re: is this my IAC valve? (Skunk2nR)
IAC is behind that manifold near the firewall of the car.
Old May 12, 2003 | 05:45 PM
IN VTEC's Avatar
EVAP isn't a sensor. It's a valve.
From the EVAP valve, run your hand to the back of the manifold. Two 12mm bolts, two coolant lines, and (1) 2P connector are the only attachments.
Old May 12, 2003 | 11:22 PM
salbaje's Avatar
its in the back next to tb
Old May 12, 2003 | 11:28 PM
civgrra's Avatar
that is an evap purge valve! iac motor is located under your throttle boddy
Old May 12, 2003 | 11:52 PM
CivicNA's Avatar
egr?
Old May 14, 2003 | 03:00 PM
mistake_2's Avatar
Default Re: is this my IAC valve? (CivicNA)
go to honda they'll tell you it's a evap purge cut solenoid.
Old May 14, 2003 | 03:43 PM
speedracer2kjory's Avatar
Default Re: is this my IAC valve? (mistake_2)
look at ur tb its behind the manifold on the right theres a couple of screws and a plug
Old May 14, 2003 | 06:36 PM
DragonTLS's Avatar
Its a purge soleniod
bigsnorlax
Jun 12, 2009 05:06 PM
Euro2JDM
Nov 15, 2006 03:58 AM
cidery
Aug 10, 2006 07:06 AM
93SSPHatch
Aug 3, 2002 11:06 PM
Gennady
Jan 21, 2002 04:39 AM
