leakdown test?
Old May 14, 2003 | 08:12 PM
SIK IN DA HED's Avatar
New User
Default leakdown test?
exactly how will a leakdown test help me figure out whats wrong with my car?
i have a problem with white smoke blowing out of my exhaust during low rpms after long drives and sometimes during regular street driving. i raced my car the other day and started blowin white smoke during idle. after a while, it went away.
i did a compression test. no signs of a leaky headgasket. i cant seem to figure it out!
Old May 15, 2003 | 11:33 AM
integracivic94's Avatar
Default Re: leakdown test? (SIK IN DA HED)
I think a leakdown test will let u know if it is your rings or valve stem seals are bad! there is a post on this somewhere!
Old May 15, 2003 | 12:25 PM
joe_bocc's Avatar
I think white smoke means your burning coolant.
Old Jul 1, 2003 | 05:49 PM
wm5holla's Avatar
Default Re: leakdown test? (joe_bocc)
explain the colors of smoke !
Old Jul 1, 2003 | 10:56 PM
blueeg's Avatar
white- burning coolant.
blue- burning oil.
black- burning rich.
Old Jul 2, 2003 | 04:09 AM
EE_Chris's Avatar
If you examine the combustion space, what components are there that aid in providing a seal....valves and rings, right. So when you do a leakdown test, you are checking to see if the pressurized air is escaping past the rings or valves. If you take off the oil cap and listen to the intake, exhaust, and valve cover, you will be able to indentify the source of the leak.
Using an input pressure of 100psi, you should not see more than 2-3% leakage with 5% being the service limit.
Old Jun 7, 2006 | 12:10 PM
xcellorator's Avatar
Default Re: leakdown test? (EE_Chris)
if a motor passes a compression test is it necessary to do a leakdown test?
Old Jun 7, 2006 | 05:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">If you examine the combustion space, what components are there that aid in providing a seal....valves and rings, right. So when you do a leakdown test, you are checking to see if the pressurized air is escaping past the rings or valves. If you take off the oil cap and listen to the intake, exhaust, and valve cover, you will be able to indentify the source of the leak.
If you pull off the radiator cap and antifreeze is getting pushed out, usually indicates a blown head gasket.
Using an input pressure of 100psi, you should not see more than 2-3% leakage with 5% being the service limit.</TD></TR></TABLE>
I always though it was 10%
Old Jun 7, 2006 | 05:23 PM
Chiovnidca's Avatar
Default Re: leakdown test? (xcellorator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcellorator &raquo;</TD></TR><TR><TD CLASS="quote">if a motor passes a compression test is it necessary to do a leakdown test?</TD></TR></TABLE>
A leakdown test will show leaks that wont show up on a compression test. A headgasket with a slight leak is a good example.
Atauto
Honda CR-V & Element
Aug 27, 2016 08:13 AM
codyweiss97
Mar 8, 2014 11:04 AM
ekLsTurbo
May 24, 2007 07:55 PM
petrv
12
Jul 14, 2003 06:33 AM
Witty
Jul 7, 2003 06:12 AM
