idling big non vtec cams
Old May 12, 2003 | 02:48 PM
JCushing's Avatar
Default idling big non vtec cams
one of the major problems with big non vtec cams is that due to the large overlap at idle you need to dump tons of fuel into the engine to idle it
ok just out of curiosity does a vacuum canister help that at all like this one?
scroll to bottom
http://www.cranecams.com/master/vacuum.htm
will this help reduce the extra fuel at idle at all? i dont really care about vacuum for the brakes im more concerned about streetability
Old May 12, 2003 | 03:24 PM
MikeMAN's Avatar
Default Re: idling big non vtec cams (JCushing)
nm
Old May 13, 2003 | 08:21 AM
JCushing's Avatar
no one?
Old May 13, 2003 | 08:43 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">one of the major problems with big non vtec cams is that due to the large overlap at idle you need to dump tons of fuel into the engine to idle it
will this help reduce the extra fuel at idle at all? i dont really care about vacuum for the brakes im more concerned about streetability</TD></TR></TABLE>
yeha on a couple customers car with huge duration LS cams, I used two extra canister and it helped idle at around 950-1000 rpm ... I got the canisters from Jegs the first time, but 2nd time I used a couple of GSR secondary runner canisters.
greg
Old May 13, 2003 | 09:00 AM
NiiS's Avatar
Just seems like dead weight to me...How much more **** can one put on to their cars? Seems like something more fiiting for a V8 or something.
Old May 13, 2003 | 09:02 AM
JCushing's Avatar
Default Re: idling big non vtec cams (sinister)
if its functional then how is it dead weight?
Old May 13, 2003 | 09:17 AM
NiiS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">if its functional then how is it dead weight?</TD></TR></TABLE>
It`s not necessary. I run the biggest stage Crower cam possible on the street(along with countless other high performance mods) and I have never had a bad idle due to lack of vacuum. So what good is it going to do for me? Nada.
There are plenty of functional thing on the market that are simply worthless...I believe this to be one of them. Just my opinon
Old May 13, 2003 | 09:20 AM
JCushing's Avatar
what cam do you run? i was thinking crower 62405a or similar cams
Old May 13, 2003 | 09:56 AM
NiiS's Avatar
63402(-2) crower`s *updated* version...LoL. They say they won`t break this time...Hmmm, we have yet to see
Old May 13, 2003 | 10:00 AM
JCushing's Avatar
maybe you missed the NON in the title of this post. you dont need a vacuum can to idle vtec cams. im talking about a non vtec cam that has the same duration all the time as the lobe of the vtec profile on the cam you are running
Old May 13, 2003 | 10:18 AM
NiiS's Avatar
Well then, I`m at a loss
lol...NON-vtec cams, I fail to read the lines, I only read in between them
Old May 13, 2003 | 12:47 PM
whatVTEC's Avatar
I can't get my car to idle for anything. When it's cold it idles fine, than once it's warmed up it won't hold and idle.
62404 crower cams
Old May 13, 2003 | 02:16 PM
1_bad_EF's Avatar
i think it has to do with compression. the higher the compression the better the car will idle. IMO, this helps the engine power through the lopeyness. I had a 11:1 cr ls that I had crower stg 3 (.427" and.420" i think) and it idled good. The guy i sold them to put them in a stock motor w/ just the head done and it idled like sheet. my other buddy's ls idled bad with the stock compression and got noticeably better when he rebuilt the bottom end w/ itr pistons.
Old May 13, 2003 | 02:24 PM
JCushing's Avatar
Default Re: idling big non vtec cams (whatVTEC)
what RPM are you guys talkin about for idle also...
Old May 15, 2003 | 07:22 AM
JCushing's Avatar
anyone else?
Haleiwa-Brando
Apr 8, 2006 04:48 AM
Teamdiesel
Jan 16, 2006 07:35 PM
dubman410
Apr 27, 2005 04:10 AM
LOWNSLOW
May 24, 2004 08:54 AM
HX_Guy
Jun 13, 2002 09:52 AM
