quick ? to check my logic in somewhat ls/vtec setup
Old May 13, 2003 | 03:33 PM
drumking15's Avatar
Default quick ? to check my logic in somewhat ls/vtec setup
I know this has nothign to do w/ an ls/vtec but it is similar....i picked up a head already plugged for the ls/vtec and the dowel pins were drilled in the other 2 holes besdies the orginally used gsr ones...so instead of unpluggin the oil passage can't i just run an oil line from my oil press sender to the vtec oil feed used in the ls/vtec setup and slap it on a gsr block..im pretty sure it will work just need some 2nd opinions, also should i use a b18b hg or the a new b18c one?
Old May 14, 2003 | 06:40 AM
JCushing's Avatar
Default Re: quick ? to check my logic in somewhat ls/vtec setup (drumking15)
are you asking if you can use an ls/vtec prepped head on a vtec block?
Old May 14, 2003 | 10:06 AM
drumking15's Avatar
yes, sorry about my dumb ? sometimes i lose my mind. I could either #1 drill out the plug and feed the oil like it orginally was...or the harder of the 2 #2 plug the oil feed supply from the block also and run an oil supply to the head where they run the vtec oil supply....correct me if im wrong but i think i got my logic together now.
libral00
Mar 30, 2008 09:57 AM
Dunc
Aug 2, 2007 08:18 PM
lsvtec1.9lcrx
17
Dec 15, 2005 04:47 PM
0554
Jul 12, 2005 05:54 AM
