polishing pistons, prep for install
Old May 15, 2003 | 08:43 AM
ludesleep's Avatar
Default polishing pistons, prep for install
Is there anything you should do to pistons before install? Some say to sand and sharpen them? Since im gonna reuse my old JE can i clean the tops with some wool?
Thanks
Bobby
Old May 15, 2003 | 08:53 PM
ludesleep's Avatar
Default Re: polishing pistons, prep for install (ludesleep)
Old May 15, 2003 | 09:00 PM
4DeepCivic's Avatar
If they haven't been "softened" then you would wanna lightly sand the top with a medium grit, then to a finer grit till it's silky smooth. Don't take off too much material and DO NOT TOUCh the valve relief.
If it's been softened. Just clean it well. If it has a lot of crap, just dip the tops of the pistons in deisel and clean away.
Old May 16, 2003 | 12:15 AM
Westrock2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">Some say to sand and sharpen them? </TD></TR></TABLE>
You can sand them, but for quite the opposite reason. You don't want any sharp edges, sharp edges build up heat quicker and can cause hot spots in the cylinder. Smoothing the piston surface may be nice, but if there JE's then chances are that they were CNC'ed and come with a pretty nice surface.
GSRCRXsi
Apr 23, 2007 03:30 AM
jtchinoy
Aug 13, 2006 01:17 PM
mike93boost
Mar 21, 2006 01:58 PM
sshaikh01
May 20, 2003 05:45 PM
ludesleep
May 15, 2003 10:47 PM
