Squeacking sound after timing belt service
I had my timing belt and water pump service on friday at my job , which is a honda dealership. But now i'm getting a squeaky sound when i start the car take of in first and just shifting gears and driving and somtimes a clunk or thump sound if i take off quick or shifting fast, but you dont hear anything when you down shift. I was periodically watching the tech do the job and i notced that the side top motor mount on the left was removed when he did the work, i'm wondering if thats whats making the noise. Now mind you i had no noises or anything when i brough to the shop. When i told the tech he was like it sounds like a rear motor mount, but i doubt it cause everything was fine beforei brought it in and as soon as picked it up i heard it. The tech is only 20 so hes new to the game. What do you guys think?
I need the help bad cause its just getting worse, i hear not when i go over bumps, and i wont be able to bring back to service till monday.
HELP!!!
HELP!!!
well your first problem is that purple and gold. it will never be as strong as black and old gold.
Hence the sqeaking. It can't withstand the pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch »</TD></TR><TR><TD CLASS="quote">well your first problem is that purple and gold. it will never be as strong as black and old gold.
Hence the sqeaking. It can't withstand the pressure.</TD></TR></TABLE>
Its been proven wrong many a times!
Hence the sqeaking. It can't withstand the pressure.</TD></TR></TABLE>Its been proven wrong many a times!
If the mechanic let the motor hang during the job it may have tweaked or ripped another mount. Put a wrench on all the motor mount bolts and check if they are tight too.
It was those 2 bolts on the left under the car that were loose, i think it was a beam or sumthin under the engine. Its good now, those 2 loose screws made my car sound like the engine was about to fall out. I'm glad I work at Honda!
Spookygeek
May 3, 2008 09:59 PM
