Big problem with clutch please help!
Old Jun 11, 2004 | 10:53 PM
GSlowR's Avatar
Default Big problem with clutch please help!
This happened tonight twice in a row.. afterwards I just stopped driving it hard..
I was in 3rd gear revv'd to 8.5k shifted then vrooooooom **** had to of gone up to 11k.. i've pushed my car hard plenty of times.. and this has not happened in the past.. but lately i've been noticing sometimes when i am driving normally the clutch kinda hangs half way mashed.. then pops up.. well combining that problem and when at high rpms and shifting i am thinking that's what caused it to just vroom up to 11k..
any ideas guys?? i'm really pissed i can't even take my car to high rpms because of this..
Old Jun 11, 2004 | 11:09 PM
MyBoostedBaby's Avatar
Default Re: Big problem with clutch please help! (GSlowR)
is yours all motor or you are running turbo? if so how many boost are you running, and what brand of clutch are you using and how long have you used them? The most common problem when that happens is that your clutch won't able to handle the power at higher rpm.
Old Jun 12, 2004 | 09:31 AM
GSlowR's Avatar
Default Re: Big problem with clutch please help! (MyBoostedBaby)
I'm all motor.. estimated at around 200 the the wheels and i have an exedy clutch/flywheel..
Old Jun 12, 2004 | 02:22 PM
Chiovnidca's Avatar
The throwout bearing could be binding. Was it lubed up real good when you installed the clutch? Does the clutch pedal come up normally or does it jump up?
Old Jun 12, 2004 | 05:37 PM
GSlowR's Avatar
Default Re: Big problem with clutch please help! (Chiovnidca)
it sticks part of the way then it just jumps up..
Old Jun 12, 2004 | 07:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSlowR &raquo;</TD></TR><TR><TD CLASS="quote">it sticks part of the way then it just jumps up..</TD></TR></TABLE>
prjctwhteg
Oct 30, 2007 05:02 AM
sodero
Aug 29, 2007 12:04 PM
TuRbEeZy
Apr 4, 2003 10:14 AM
taytay333
Nov 21, 2001 12:58 PM
