weird Wheel problem
Old Jun 11, 2004 | 08:33 PM
asmallsol's Avatar
Default weird Wheel problem
When I first bought my car, it had a slight pull to the right, but I figured it was just out of alignment. I did an alignment, and everything was in spec, but it still pulled to the right. Later, I got diffrent wheels (rota's with potenza so3's), and without any other adjustments (alignment) the car tracked perfectly straight. During the winter, I had a diffrent set of wheels, (teg fat fives) with all seasons, and the car still tracked perfectly.
In the past few months, my potenza's have been getting pretty worn (tons of drag racing, autocross, road course) and also I flat spotted one of them last week, so I decided to put my stock wheels back on. As soon as I put them on, the pull is back.
I don't understand it. All four tires are the exact same tire, all have the exact same amount of where, all the same pressure.
What could it be? Could it be the tire? Could the wheel be at fult.
Old Jun 12, 2004 | 06:33 AM
asmallsol's Avatar
bump I need an answer quick
Old Jun 12, 2004 | 07:11 AM
Chiovnidca's Avatar
Default Re: (asmallsol)
Tires do that sometimes. Cross the front tires to see what happens.
Old Jun 12, 2004 | 09:02 AM
asmallsol's Avatar
Default Re: (Chiovnidca)
all right, I'll try that.
Old Jun 12, 2004 | 05:58 PM
BigMoose's Avatar
I'll vote for the tires too. Its funny, they can look very normal with respect to even wear, but still cause a pull.
Old Jun 12, 2004 | 07:36 PM
Chiovnidca's Avatar
Default Re: (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">I'll vote for the tires too. Its funny, they can look very normal with respect to even wear, but still cause a pull. </TD></TR></TABLE>
Yep, 9 times out of 10 when we get a pull or drift complaint, it's the tires.
Old Jun 12, 2004 | 08:13 PM
asmallsol's Avatar
cool, thats what I wanted to know. This winter I am going up to the Upper Pennisula of michigan to Michigan tech (if you think of it as a rabit, its up in the ear) So theres going to be ALOT of snow. Anyways, I am going to put some snow tires on my Stock sol wheels, so I wanted to make sure that that was the problem before I bought the snow tires. Thanks for the replys
Old Jun 12, 2004 | 08:53 PM
Super_Eg6's Avatar
Default Re: weird Wheel problem (asmallsol)
could it have just been the orignal wheels, couldnt they have been bent to cause the off alignment...
Old Jun 12, 2004 | 09:18 PM
Chiovnidca's Avatar
Default Re: weird Wheel problem (Super_Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">could it have just been the orignal wheels, couldnt they have been bent to cause the off alignment...</TD></TR></TABLE>
Bent wheels will usually cause a vibration or wobble.
mikeunreal2
Jun 3, 2007 12:12 PM
ericlee303
Apr 1, 2006 05:08 PM
hi mom
Jul 8, 2004 09:12 PM
sslude
Jun 11, 2003 12:50 PM
performula
12
Sep 11, 2002 07:49 PM
