I need help on an odd no start condition....95 EX...
Old Jun 13, 2004 | 03:36 PM
Bailhatch's Avatar
Default I need help on an odd no start condition....95 EX...
kind of a puzzler for me so i hope you guys can steer me in the right direction.
The car is a 95 ex, auto tranny with a mild t25 turbo setup.
With no signs it just would not start one day. Cranks fine but i'm pretty sure the ECM isn't getting power for some reason. I swapped in a known good Main Relay, no dice. All fuses under the hood and on the interior fuse box are good. No lights on the dash come on when you turn the car on. fuel pumps don't turn on. dizzy doesn't fire...(swapped in a known good dizzy)
Any ideas? are there any other common problems I could check for. Anyone know what ECU pins to check for switched power?
TIA!
Old Jun 14, 2004 | 09:41 AM
Bailhatch's Avatar
Default Re: I need help on an odd no start condition....95 EX... (Bailhatch)
could a bad ignition switch be the problem?
NotAJDMFanBoy
Apr 21, 2020 08:21 PM
Popsgarage
Oct 10, 2015 07:36 PM
jdmvtec@413
10
Aug 11, 2008 12:04 PM
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
caliskier
Aug 21, 2007 02:07 PM
