SOHC ZEX cam timing question HELP?
Old Jun 8, 2004 | 06:20 PM
JdmIntegra98's Avatar
Default SOHC ZEX cam timing question HELP?
Ok friend has a SOHC OBD2 CIVIC EX car has mid-zex cam in it with cam gear... what should we doo.. advance gear 3 degrees??? and leave ignition timing stock... or advance ignition timing too??? also what is stock ignition timing on that car??? Please help...
Old Jun 9, 2004 | 08:03 AM
Default Re: SOHC ZEX cam timing question HELP? (JdmIntegra98)
any ideas?
Old Jun 9, 2004 | 11:28 AM
help
Old Jun 10, 2004 | 01:48 PM
nickatiah's Avatar
Default Re: (JdmIntegra98)
ok bro. you should really search first but heres your answers anyway.
everytime you adjust the cam timing (cam gear) the ignition timing needs to be reset cause the dissy is cam driven.
the stock ignition timing for that motor is 12* BTDC.
and the only way to properly tune cam timing is with a dyno. cause all your doing is adjusting the the powerband.
now my question: exactly which cam did he get i'm interested in one my self.
cliff666
Apr 19, 2006 10:49 AM
Red_Si
Apr 20, 2004 07:21 PM
Jockobo
Jan 23, 2003 03:48 PM
redcxhatch
Nov 16, 2002 08:04 AM
N1Spec
Nov 18, 2001 11:15 PM
