VAFC initial settings??
Old Jun 9, 2004 | 10:23 PM
B00ST2nR's Avatar
Default VAFC initial settings??
Ok, so I'm gonna be swapping out my Skunk2 cams back to stock GSR cams and cam gears soon. Now once I get the stock cams back in, I know I should either take off the VAFC or go back to the Initial Settings of the ECU.
My question is:
If I initialize my VAFC settings, will it go back to all stock settings? In other words, if I initialize the VAFC, will it run as if I had no VAFC hooked up to my p72 ecu?
Old Jun 10, 2004 | 07:45 AM
B00ST2nR's Avatar
Default Re: VAFC initial settings?? (B00ST2nR)
no one?
Old Jun 10, 2004 | 08:35 AM
showtymers619's Avatar
* B A N N E D *
actaully when you initialize you have to set the setting back... like cyl # and sensors that that arrow thing .. if those arent resetted and only your fuel plus and minus set ups are all at 0 then you are at stock
Old Jun 13, 2004 | 10:01 PM
Pandahatch's Avatar
Initialize it, set your sensor to 6 in 6 out and set your throttle position sensor, then don't touch anything. You may have to adjust the VTEC point though, set it to stock.
ALMXDUPINTEGRA
May 9, 2005 01:48 PM
IgniteTeg
May 3, 2002 12:06 PM
IgniteTeg
May 3, 2002 01:22 AM
IgniteTeg
May 2, 2002 07:23 AM
IgniteTeg
May 2, 2002 03:00 AM
