Just did compression test..
Old Jun 8, 2004 | 05:36 PM
typeeg's Avatar
Default Just did compression test..
205 205 215 235
Not sure why the fourth cylinder is a lot higher than the others.
I noticed greyish smoke at WOT and vtec occasionallly which is why I did the test.
I also noticed oil along the threads of all four spark plugs. Recently removed my valve cover but I sealed the o-rings with high temp RTV so I doubt it's leaking from here. Could it be bad rings? If so are my numbers indicitive of that? Thanks in advance.
Old Jun 8, 2004 | 06:01 PM
typeeg's Avatar
Default Re: Just did compression test.. (StockEG9)
Old Jun 8, 2004 | 06:52 PM
typeeg's Avatar
anyone?
Old Jun 8, 2004 | 06:59 PM
typeeg's Avatar
I was thinking that my rings may be bad which is why there is oil on the threads of the spark plugs BUT if that was really the case then wouldn't the electrodes be soaked in oil as well?
Old Jun 8, 2004 | 08:10 PM
typeeg's Avatar
anyone got any input?
Old Jun 9, 2004 | 05:49 AM
typeeg's Avatar
help me out here
Old Jun 9, 2004 | 06:56 AM
TIRENECK's Avatar
thats fine #s, as long is not like this 180 205 215 235 but yea the engine might need replacement soon.
Old Jun 9, 2004 | 06:58 AM
typeeg's Avatar
Default Re: Just did compression test.. (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">thats fine #s, as long is not like this 180 205 215 235 but yea the engine might need replacement soon.</TD></TR></TABLE>
You just said the numbers are fine but then said I might need a replacement soon. ?? please elaborate
Old Jun 9, 2004 | 07:05 AM
mmuller's Avatar
Mad Scientist
your #'s are ok; cyl. # 4 might just have carbon buildup on it, buy soem seafoam and use it.
the spark plug prolly has oil on the threads because of a leaking valve cover O-ring gasket.
Old Jun 9, 2004 | 07:31 AM
typeeg's Avatar
Default Re: Just did compression test.. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">your #'s are ok; cyl. # 4 might just have carbon buildup on it, buy soem seafoam and use it.
the spark plug prolly has oil on the threads because of a leaking valve cover O-ring gasket. </TD></TR></TABLE>
If the o-ring gasket was bad or worn, wouldn't oil be on the white part and the walls of the spark plug well and NOT on the thread? If there is oil on the thread I would think that the oil would be comming from bottom (combustion chamber) not the top. The wierd thing is there isn't any oil on the electrodes... if it were comming from the bottom then i would think they would be wet as well
Old Jun 9, 2004 | 07:44 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">
If the o-ring gasket was bad or worn, wouldn't oil be on the white part and the walls of the spark plug well and NOT on the thread? If there is oil on the thread I would think that the oil would be comming from bottom (combustion chamber) not the top. The wierd thing is there isn't any oil on the electrodes... if it were comming from the bottom then i would think they would be wet as well </TD></TR></TABLE>
hehe, if you would be leaking so much oil through the rings or hg. and leaking from the combustion chamber to the spark plug threads, then that cyl. would be useless; meaning you would burn LOTS of oil and foul spark plugs.
its comming from the top, not the bottom
Old Jun 9, 2004 | 07:49 AM
typeeg's Avatar
its comming from the top, not the bottom</TD></TR></TABLE>
Hmm... well I DO spit out some greyish smoke at WOT and higher rpm's... I just don't see how oil from the top can get the threads since the thread is below where the oil can reach down into... I checked the o-ring gaskets and they are like new. I guess I can get new ones anyway..
Old Jun 9, 2004 | 08:14 AM
mmuller's Avatar
Mad Scientist
Hmm... well I DO spit out some greyish smoke at WOT and higher rpm's... I just don't see how oil from the top can get the threads since the thread is below where the oil can reach down into... I checked the o-ring gaskets and they are like new. I guess I can get new ones anyway.. </TD></TR></TABLE>
well, just think about it.. if you had that much oil on the combustion chamber that it would seep it to the spark plug threads like that the car would run like ****...you would eventually foul plugs.
gooblinn258
May 30, 2014 12:20 PM
SimplyTron
Jul 27, 2007 06:50 PM
dunkd
Aug 8, 2006 01:35 PM
GSR4door1
Mar 31, 2004 06:39 PM
Aeka GSR
Oct 4, 2002 11:44 PM
