cltuch problems
Old Jun 12, 2004 | 08:33 AM
brdystyls's Avatar
Default cltuch problems
Ok, here's the deal. I just swapped out my clutch a bought a new clutch kit from a Honda dealer (so the parts are right and new). I also resurfaced my flywheel and replace my Master and Slave Cylinder. There are no leaks in the lines either. Ive been through 4 different clutches and it still will not go into gear when the car is on. Im thinking either the flywheel was machined wrong (doubtful) or the release fork is bent (also doubtful since it was working fine before I did the swap). I am at my wits end here. I need help fast! HELP!!!!!!!!!!
Old Jun 12, 2004 | 08:54 AM
brdystyls's Avatar
Default Re: cltuch problems (brdystyls)
just wanted to add....
Should the teeth (splines or forks), whatever their called on the pressure plate, lie flat or should they point towards the release bearing. If so would this suggest that the flywheel was machined imporperly? Or is it the wrong pressure plate?
Old Jun 13, 2004 | 12:18 PM
spooned out's Avatar
um what kind of car? tranny?
Old Jun 13, 2004 | 01:50 PM
brdystyls's Avatar
Default Re: cltuch problems (spooned out)
honda del slow (for now)
D16Y8
Stock Tranny
Si Sohc VTEC
Dcparker2929
Transmission & Drivetrain
Sep 20, 2014 11:55 PM
7rrivera7
Jun 28, 2013 04:27 PM
92accordh22a
Jan 17, 2007 07:45 AM
trus01d1er
Nov 12, 2006 11:03 PM
brdystyls
Jun 17, 2004 07:53 AM
