b18c1 with piston questions
Old Jun 13, 2004 | 02:29 PM
totally jay's Avatar
Default b18c1 with piston questions
hey , i have a b18c1 stock that has spun a bearing or thrown a rod
im looking to put in either stock usdm itr pistons( i have a set now that i got for cheap) or a set of ctr or jdm/usdm si pistons
i want more power i may be going with better then stock cams but not at this time
i will be rebuilding my block or just buying a diff b18c1 block and using what parts i can from my block and making an engine . .
so what should i do in a block rebuild?
i wanna run faster and use one of the pistons i said above( ctr,itr,si)
do i need bigger injectors for those pistons?
what rods should i use ?
should i get oversized pistons?
sorry for all the questions im reading everything i can, thanks guys
Old Jun 13, 2004 | 03:13 PM
99B16Si's Avatar
put some jdm itr pistons in it and some ITR cams and call it a day. the crank along with atleast one rods im sure is fucked so if u plan on rebuilding that block look for another crank
Old Jun 14, 2004 | 02:31 AM
Default Re: (99B16Si)
how much do you think that would cost to rebuild it, like a guestamit(just a guess)
and how much do you think it would cost for a used block and get that cleaned up with jdm itr cams and jdm itr pistons ??
thank you . .
Old Jun 14, 2004 | 07:53 AM
99B16Si's Avatar
pistons generally go for about 300 with rings and then a used gsr block is usually about 800 plus labor and everything else you could be looking well above 1000
Old Jun 14, 2004 | 11:20 AM
i got usdm itr pistons without rings or rods for like 60 already
and im lookin at a used gsr block for about 600$
then i prob need a new crank and rods ( if the above block doesnt come with that )
Old Jun 15, 2004 | 12:05 PM
Default Re: (totally jay)
bump please
Old Jun 21, 2004 | 09:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totally jay &raquo;</TD></TR><TR><TD CLASS="quote">bump please</TD></TR></TABLE>
japscrap
Apr 8, 2009 01:43 PM
kings**t
Apr 24, 2008 06:16 PM
bon3z1201
Sep 26, 2006 01:51 AM
Alaskan98ITR406
Dec 13, 2002 12:20 PM
Stop the Beast
Aug 9, 2002 04:06 AM
