Ignition timing bouncing...??
Old Jun 8, 2004 | 06:25 PM
JdmIntegra98's Avatar
Default Ignition timing bouncing...??
I have a good timing light and it shows my ignition timing bounceing back in forth a small percentage... like 2-3 degrees... just the lil marking moves around a bit once i set it... i think i might have a faulty o2 sensor.. but is there anything else it could be or is o2 sensor even related to that ?
Old Jun 8, 2004 | 06:55 PM
StorminMatt's Avatar
Default Re: Ignition timing bouncing...?? (JdmIntegra98)
This could be due to imperfections in the timing belt. But the oxygen sensor probably has no effect.
Old Jun 8, 2004 | 10:07 PM
uhh... my idle feels funny too.... and my timing is off... so could that effect it?>
Old Jun 8, 2004 | 11:38 PM
mmuller's Avatar
Mad Scientist
did you jump the service connector?
you need a stable idle in spec to adjust timing
Old Jun 9, 2004 | 08:02 AM
yes it was jumped
Old Jun 9, 2004 | 08:10 AM
mmuller's Avatar
Mad Scientist
Default Re: (JdmIntegra98)
check your cam timing
Old Jun 9, 2004 | 10:48 AM
cams are stock.. stock cam gears.. so how would i change or check cam timing?
Old Jun 9, 2004 | 06:23 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmIntegra98 &raquo;</TD></TR><TR><TD CLASS="quote">cams are stock.. stock cam gears.. so how would i change or check cam timing?</TD></TR></TABLE>
mmm ok...dont check it then....
crfreestyle
Classic Hondas
Dec 21, 2009 02:36 PM
johnwohl
Apr 1, 2008 07:29 PM
neoc03
Jul 18, 2007 08:09 AM
donnjuan2point2
Mar 11, 2004 10:49 AM
