New forged pistons
Old Jun 12, 2004 | 08:46 PM
GWInquisitor14's Avatar
Default New forged pistons
If I wanna get new forged pistons for a B18b block, am I going to need sleeves also or will I be fine?
Old Jun 12, 2004 | 10:38 PM
Default Re: New forged pistons (GWInquisitor14)
bump
Old Jun 13, 2004 | 05:27 AM
Fobtions's Avatar
if stock bore, you dont need sleeves. depending on whut you plan on doing.
Old Jun 13, 2004 | 08:38 PM
Default Re: New forged pistons (Fobtions)
well i plan on boosting it, so id want to add low comp pistons. I want the sleeves eventually, but i dont have the cash for em
Old Jun 13, 2004 | 10:02 PM
someone told me that forged pistons will expand and rub against the stock honda sleeves
Old Jun 13, 2004 | 11:26 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">someone told me that forged pistons will expand and rub against the stock honda sleeves</TD></TR></TABLE>
yeah, thats why you run more piston to cyl. wall clearance.
forged pistons will be a lot harder on your cyl. walls no matter what.
Old Jun 14, 2004 | 10:11 AM
Default Re: New forged pistons (mmuller)
run more or run less? cuz if u run more, isn't there a greater possibility of rubbing when it expands?
Old Jun 14, 2004 | 10:32 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">run more or run less? cuz if u run more, isn't there a greater possibility of rubbing when it expands?</TD></TR></TABLE>
no, if you run less clearance it will rub more.....forged pistons run more clearance, thats why when cold they slap
Old Jun 14, 2004 | 10:37 AM
N2O's Avatar
N2O
If you run more piston to wall clearance than there is more room for the pistons to grow. the piston manufacturer will be able to tell you what clearance to run. the amount of clearances also depends on the compression of the piston and the amount of boost and or N2O you are going to be running.
Old Jun 14, 2004 | 10:41 AM
mmuller's Avatar
Mad Scientist
Default Re: New forged pistons (N2O)
ya, for example:
stock PTWC is : around .0016
and lets say...Endyn/Wiseco run around 0.0021-0.0022
Old Jun 16, 2004 | 10:41 AM
oh yah duh LOL i must have misinterupted that. Is that all u need to do to make sure the piston wont rub?
Old Jun 16, 2004 | 06:45 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">oh yah duh LOL i must have misinterupted that. Is that all u need to do to make sure the piston wont rub?</TD></TR></TABLE>
kinda, i mean it all depends on what your goals are; for example for NA you dont need such a big ptwc because they wont expand as much as FI applications.And tighter clearance is better for longevity and ring seal.
For FI applications also differs in how much boost you going to run....more boost= more clearance
WalkerGSR1
Sep 4, 2006 10:53 AM
CBURKE
Nov 14, 2005 05:29 PM
dizzyroc88
Mar 15, 2005 05:57 PM
DMF
37
Dec 28, 2004 10:44 PM
integranator
Aug 6, 2003 09:23 PM
