Idle Adjustment Problem... Need Help. :(
Old Jun 13, 2004 | 11:41 AM
LSVTEC 91 Civic's Avatar
Banned
Default Idle Adjustment Problem... Need Help. :(
I turned my idle up 100RPM because it was idleing too low, espically with all my accessories on. So, after I did the adjustment, my engine billows out grey smoke and condensation all over the place. What went wrong???
Old Jun 13, 2004 | 12:50 PM
Banned
Default Re: Idle Adjustment Problem... Need Help. :( (LSVTEC 91 Civic)
Here are the photos:
Now I'm begining to think I adjusted idle in the wrong place. After the fact, I did some HT searches, and found that the correct way to adjust idle is to unplug IACV solenoid then adjust the screw on the top left hand side of the throttle body (search own3d me), instead of the screw and adjusts throttle linkage. I'm not sure how to fix my problem... Anyone?
Modified by LSVTEC 91 Civic at 10:43 PM 6/13/2004
Old Jun 13, 2004 | 01:29 PM
EL Vap133's Avatar
PM'd you.
Old Jun 13, 2004 | 06:09 PM
Banned
Default Re: Idle Adjustment Problem... Need Help. :( (EL Vap133)
I used my VAFC to put it back where it was supoused to be, but still smokes horribly :-x
Old Jun 13, 2004 | 06:23 PM
Full Race A6's Avatar
I didnt even touch the VAFC, on the left side of the throttle body there is just a little screw for a flat head, my problem was a high idle, I just turned it until the car wanted to die and sharted to shake and turned back the other way maybe 45 degrees
Unless of course you actually have an ls/vtec motor, this was for an OEM Si tb
Old Jun 13, 2004 | 08:43 PM
navin's Avatar
Default Re: Idle Adjustment Problem... Need Help. :( (W O T)
any insight on this...
my car does the condensation thingy at Idle... and my idle is all whacked out too...
my friend messed with a nut on the TB, thinking it was the idle ajustment....
Old Jun 14, 2004 | 01:38 PM
Banned
Default Re: Idle Adjustment Problem... Need Help. :( (navin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin &raquo;</TD></TR><TR><TD CLASS="quote">any insight on this...
my friend messed with a nut on the TB, thinking it was the idle ajustment....</TD></TR></TABLE>
After doing searching, that nut adjusts the TPS Sensor voltage, its has to be .5v at idle, and .45v at full thottle, I corrected it, and is still smoking a little.
Strange.
followthadollar
Apr 21, 2010 02:46 PM
gutted-dx
Dec 18, 2005 09:08 PM
kaj
Sep 1, 2004 04:37 PM
vtecmike1
Jul 30, 2004 02:20 PM
TurbodCX
May 8, 2002 07:16 AM
