NO FUEL - NEED HELP!
Old Jun 9, 2004 | 06:55 AM
IntegraB18's Avatar
Default NO FUEL - NEED HELP!
ok heres my problem....i had a 98 b18c1 in my 94 hatch wit some mods and a v-afc....had some problems with it so i took it out and put in a 1st gen b16 so i can get around while i rebuild my b18...i also took out my v-afc becuz with the stock b16 it would run like **** wit the program i had in there....i go to start the car and the fuel pump is not comin on....i check the ecu i check the fuse for the ecu but i dont know wat else will cause this...some ppl think it has something to do with the v-afc but the fuel pump or my afc didnt come on when i tried to start It for the first time....so i took the afc out and still nothin..NEED SOME HELP ASAP!...THANKS
Old Jun 10, 2004 | 05:13 AM
IntegraB18's Avatar
Default Re: NO FUEL - NEED HELP! (IntegraB18)
ok i kinda figured out what the problem is but i dont know how to fix it...the fuse under the dash for (A C G) keeps blowin out....i dont know why and i dont even know what (A C G) is...can anyone help me o this one?
Old Jun 10, 2004 | 07:15 AM
AllMoToRB18c's Avatar
bump
Old Jun 10, 2004 | 09:39 AM
kamikazeCRX's Avatar
Default Re: NO FUEL - NEED HELP! (AllMoToRB18c)
Check your main relay...take it out and run it through the test procedure to make sure it all works. It should explain how to do all this in a haynes manual if you don't already have somthing like this.
Old Jun 10, 2004 | 07:35 PM
IntegraB18's Avatar
Default Re: NO FUEL - NEED HELP! (kamikazeCRX)
ok ill do that..but im still curious on what (ACG) stands for...the dealer couldnt even tell me...they said ill have to come in for them to look at it....(of course so they can make money)...thanks for ur help....where is the main relay by the way?
Old Jun 11, 2004 | 05:36 AM
IntegraB18's Avatar
bump
flaco1978
Apr 19, 2006 04:49 PM
rollercosta123
Aug 7, 2005 09:22 PM
Ri5e
Jul 5, 2005 01:16 PM
blkcoupe94
May 3, 2005 10:24 PM
iwhichisme
Sep 8, 2004 05:47 AM
