GSR Wiring Issues
Old Jun 10, 2004 | 09:41 PM
TurboTeG4's Avatar
Default GSR Wiring Issues
When I bought my gsr I didnt know but all the wiring was cut in various points. On the engine side the harness is cut and every wire has a butt on them with the 2 ends of the wires in one side of the butt. On the chassis side(3 plugs on passenger side engine mount area)is also cut same situation. By the ecu same thing, even wires not tapped into is cut with a butt on them. Also by the drivers side firewall the plug is cut and tapped into the other side, but upon inspection some wires dont match the colors of the ones tapped into.
My car was throwing a code 3 for a while, I hardly drive the car its a 94 clean title with 52k miles. 2 days ago I redlined 1st and went to 7k in 2nd and now my car has big blow by. I have not checked compression yet, but I have a built motor comin from spark racing and I was awaiting it to do a full blown turbo setup. One point my vafc was goin on /off and it was the power wire by the ecu was not connected solidly in the butt, should be soldered to begin with.
How hard is it to change the wiring that goes to the ecu, etc(chassis wiring?). Im good with wires but is it mass confusion? The car was running however with whatever way the wires is connected.
Old Jun 11, 2004 | 12:51 AM
TurboTeG4's Avatar
Default Re: GSR Wiring Issues (TurboTeG4)
does the 94 gsr ecu wires go straight out the firewall and into the engine bay, plug n play?
Old Jun 11, 2004 | 09:45 AM
TurboTeG4's Avatar
Old Jun 11, 2004 | 03:21 PM
Retired's Avatar
WEST COAST
Cortesy of http://www.ff-sqaud.com
Old Jun 13, 2004 | 06:38 PM
TurboTeG4's Avatar
Default Re: GSR Wiring Issues (SPARK RACING INC.)
AHh turns out someone tried to steal her and cut it all up. Theres civic plugs instead of teg plug so the wire colors are different. I resoldered everything exept by the ecu-My Back Aches!!!!!
Mikey3000
Jul 13, 2008 07:57 AM
iheartamy
Dec 23, 2006 08:43 AM
DShowers
Jan 29, 2005 12:47 PM
FourthGenHatch
Sep 2, 2003 04:20 AM
HKSone
Jul 10, 2003 04:53 PM
