ITR pistons GSR block?
Old Sep 6, 2002 | 08:28 AM
HybridHatchC1's Avatar
Default ITR pistons GSR block?
i was searching the net just looking for some parts to buy for my new b18c1 and i have been coming across ITR pistons and itr pistons/gsr rod combos and i know a couple people said they has that itr/gsr setup my questions is, is it really worth the buck? i mean i am not going for a moneter build just a low 13 second car
Old Sep 6, 2002 | 10:25 AM
Katman's Avatar
Default Re: ITR pistons GSR block? (Civ-JDM)
Yes its worth doing. Raising compression levels is a needed thing to do when bulidng power for a naturally aspirted engine. Raising compression ratio also helps out when using big lift/duration camshafts.
[Modified by Katman, 11:26 AM 9/6/2002]
Old Sep 6, 2002 | 03:30 PM
Tweakmeister's Avatar
is it worth the buck?
depends on how much it runs you! raising compression is definately one of the best ways to go (if you aren't going FI). You could even run higher like CTR pistons...
Old Sep 6, 2002 | 09:35 PM
Default Re: ITR pistons GSR block? (Tweakmeister)
225shipped with rings rods/pistons, think i should hit the deal up while the motor is still out. , and i couldnt find a obd1 p72 so i am going to run a skunk2 chipped p28.
Old Sep 7, 2002 | 08:28 AM
like I said, if you can do it then by all means go ahead with more compression. how far you go will depend on a a lot of things, including what you are doing with your valves.
Throw in at least ITR pistons. If you want to chip it then IM "kenji" on this board.
CarbonfiberR
Feb 14, 2009 10:05 AM
wreckeddc4
Aug 20, 2007 09:30 AM
candy eg
Apr 22, 2006 04:56 PM
lazyvietboi
Nov 5, 2001 07:44 PM
