Micrometers: Friction THimble or Ratchet Stop
Old Sep 4, 2002 | 08:20 AM
IN VTEC's Avatar
Default Micrometers: Friction THimble or Ratchet Stop
Which type do you prefer to use?
Friction thimbles are more accurate in reading the real size of the item.
But, ratchet stops are easier to use and yield more precise (consisten) readings for beginning users.
I'm deciding which type to get.
.: Mitutoyo 103-135 [friction thimble] vs 103-260 [ratchet stop] (0" - 1" micrometer :: accurate to 1/10000th's using a vernier scale)
.: Mitutoyo 103-136 [friction thimble] vs 103-262 [ratchet stop] (1" - 2" micrometer :: accurate to 1/10000th's using a vernier scale)
.: Mitutoyo 103-217 [ratchet stop] (2" - 3" micrometer :: accurate to 1/10000th's using a vernier scale)
Pricing is about the same for either.
http://www.use-enco.com/hotdeals/MeasuringTools.cfm
http://www.use-enco.com/hotdeals/hd0902/44.pdf
[Modified by IN VTEC, 11:20 AM 9/4/2002]
Old Sep 4, 2002 | 12:43 PM
BROOD's Avatar
Default Re: Micrometers: Friction THimble or Ratchet Stop (IN VTEC)
I've always used friction thimble mics with no problems. But I guess that really doen't help you compare them much. A bump is the best I can do.....
[Modified by SLPR, 1:43 PM 9/4/2002]
Old Sep 4, 2002 | 03:09 PM
BigMoose's Avatar
FWIW I have both styles. I do not use the ratchet stop even when it is in my hand. Just don't like the feel of it. Friction Thimble is my choice.
Regards,
BigMoose
Old Sep 4, 2002 | 03:17 PM
rastropovitch
Guest
Posts: n/a
There both good. A Mic of .010" is not super accurate anyways.
Peace
Schu
Old Sep 4, 2002 | 05:05 PM
IN VTEC's Avatar
Default Re: Micrometers: Friction THimble or Ratchet Stop (MSchu)
I guess the biggest issue with using micrometers is knowing when to stop.
The best I've heard is that you try to rock the micrometer from side-to-side to make sure you have the surface being measured, parallel to the anvil. I've tried that and my crank main journal reading came out on the small side.
I was hoping that the ratchet stops would help me to gauge when to stop and keep me from being so indecisive as to when to stop and take the reading.
Old Sep 5, 2002 | 06:34 AM
rastropovitch
Guest
Posts: n/a
It takes a very lite, specific touch. you get it once you've experienced it. Rocking it is a technique, but its not like really rocking, twisting. Practice on calibration stones or anvils and you get the touch.
Peace
Schu
ITRSpeed
Feb 9, 2004 05:26 PM
93si
Jun 2, 2003 08:32 AM
Solo2Cvc
Dec 10, 2002 01:43 PM
