90 CRX Starting problems
sometimes my car will crank but will not start. It seems to not be getting fuel. If I let it set a few min. It will then start fine. It has never died, Just fails to start once or twice a week. Any one have an idea?
Thanks for the response
My only thought was a bad connection on the Key switch.
I will get the new fuel relay and see how it does
Thanks again.
[Modified by gcajnr21, 6:44 PM 9/8/2002]
Thanks again.
or if you have soldering skills you can pop open the relay and re-solder all of the connections to the circuit board. but if you can't solder, dont try. maybe you know someone that can if you can't. anyways its an easy way to save $50
goodluck
goodluck
1slowSIrex
Jul 24, 2006 10:07 PM
