ECU Fuse keep on Blowing PLEASE HELP
Old Sep 7, 2002 | 08:56 PM
Metal_SOL's Avatar
Default ECU Fuse keep on Blowing PLEASE HELP
I was driving, the suddenly my car died, i checked for spark, fuels, thers was nothing, i check the fuse box, the ECU fuse were blow, then i replaced it, then it blow again when i turn on the keys, Can any one thinks of what could have been the problems or how to check it?? I replace the ECU with the same one but the fuse still blowing, PLEASE HELP
Old Sep 7, 2002 | 10:10 PM
Flamenco-T's Avatar
Default Re: ECU Fuse keep on Blowing PLEASE HELP (power_civic)
fuse blown = bad ground
check all your grounds, which fuses blew ? it'll help if you can be mroe specific then we can try to locate where the bad ground depending on which fuses blew...
stan
Old Sep 8, 2002 | 06:43 AM
Mikey3000's Avatar
what kind of car is this? the same thing happened with my H22/Civic until i installed a resistor box.
Old Sep 8, 2002 | 08:31 AM
shermanyang's Avatar
Default Re: ECU Fuse keep on Blowing PLEASE HELP (Salvatore Leone)
hmm...whenever i get a blown fuse it's always because a positive wire somewhere is loose or something and is touch ground. that has always been my case. maybe yours is different. my buddy just recently had the problem that you were having, but i think his went away after switching trying it twice and taking out the ecu to have a look at it. he said it was because of the after market chip he had installed.
Joshb152
Oct 9, 2015 09:10 PM
crookson speed
Feb 25, 2014 12:02 PM
mazik11
Dec 23, 2005 05:24 PM
Metal_SOL
15
Sep 9, 2002 09:41 PM
dohc_Cx
Jul 27, 2001 10:03 AM
