idle problems...check engine
Old Sep 3, 2002 | 11:24 AM
si95's Avatar
Default idle problems...check engine
i have a 95 si h/b. it idles really low...sometimes it even dies. when i drive the car for a period of time, check engine comes on and i guess the car runs on safe mode or something like that....the cars just boogs, like too much fuel. i tried checking what the code was but all it gave me was nothing i could read(the light just twitches...too fast to read). can anyone explain that or give me a solution to my problems? HELP...
Old Sep 3, 2002 | 11:29 AM
Spade's Avatar
Default Re: idle problems...check engine (si95)
Try pulling code again but clean the connector and pin with rubbing alcohol.
Old Sep 3, 2002 | 11:42 AM
si95's Avatar
Default Re: idle problems...check engine (Spade)
tried that...still the same. any other suggestions.
Old Sep 3, 2002 | 07:53 PM
TREVER's Avatar
check your grounds
Old Sep 4, 2002 | 10:19 AM
si95's Avatar
Default Re: idle problems...check engine (TREVER)
everything looks fine. another thing too is that most of the time it happens is when i'm driving it hard...and sometimes in the morning when i first drive it?! what the hell is going on with my car...................
Old Sep 4, 2002 | 10:30 AM
vtec.dc2's Avatar
open your distributor cap, check distributor rotor - if you see the metal part fried/rusted, it may be the problem.
Old Sep 4, 2002 | 11:10 AM
PyroVTEC's Avatar
New User
Check vacuum lines. Vac leaks can cause low idle.
Old Sep 4, 2002 | 03:59 PM
salbaje's Avatar
check sparkplug wires, rotor, distributor cap, vacuums. what code is it throwing??
Old Sep 4, 2002 | 05:00 PM
B00ST2nR's Avatar
Default Re: idle problems...check engine (salbaje)
how low is your idle?
Old Sep 5, 2002 | 11:42 AM
si95's Avatar
Default Re: idle problems...check engine (Skunk2nR)
it idles very low...like under 500 rpm. idles so low sometimes it dies?! i've check all the ignition and they're all good. ??????
buzlink
10
Aug 28, 2009 11:00 AM
LUKE 92 GS-R
Aug 12, 2008 03:07 AM
forcedaccord95
Nov 30, 2004 04:14 PM
civcexcoupeblack
May 22, 2003 06:44 AM
IntegD
Feb 6, 2002 12:27 AM
