how to check compression
Old Nov 3, 2002 | 05:39 PM
F.U.'s Avatar
Default how to check compression
I know it has been posted but couldn't find anything....I am a horrible man at the search button...how do i check for cmpression in my cylinders...tia
Old Nov 3, 2002 | 07:13 PM
SOUTHCREX's Avatar
Default Re: how to check compression (Honda Tech)
Heat the car up to normal temp
Pull the fuel fuse
oil the o ring on the comp tester
screw it in
open the tb 100% turn the car over 5 or 6 times
This is only info that I remember reading a few days ago on h-t, someone else might wanna add to it.
Old Nov 3, 2002 | 07:23 PM
Kamin's Avatar
Default Re: how to check compression (Garage Shiftdown)
pull the spark plugs out
forgot that.
Old Nov 3, 2002 | 07:44 PM
Chiovnidca's Avatar
Make sure to disable the ignition system so you don't fry your coil.
Old Nov 10, 2002 | 01:27 PM
J Money's Avatar
Default Re: how to check compression (Chiovnidca)
How do you open the TB 100% and where do you go to disconnect the coil? Thanks in advance.
Old Nov 10, 2002 | 02:09 PM
Desslok's Avatar
Default Re: how to check compression (J Money)
just pull your ECU fuse.
Old Nov 10, 2002 | 05:33 PM
Jared's Avatar
Default Re: how to check compression (sp)
make sure you pull the plugs out as not to load the starter, and the throttle should be wide open as well.
aguynamedpat
Jun 4, 2009 07:30 PM
Avengeance
Jul 23, 2006 03:51 PM
monkijunki
Dec 2, 2003 03:16 PM
EG6owner-T
Oct 29, 2002 05:16 AM
