TODA cams
Old Nov 2, 2002 | 10:55 PM
LHC's Avatar
LHC
Default TODA cams
can you guys tell me how the driveability of my car will change if I decide to go spec b toda cams/i've kinda heard it mentioned in another thread that the idle rpm will go up and stuff but is there any other 'change' that the cams will cause to the daily driving? reason i ask is that i dont want to get any surprises after they are installed
Old Nov 3, 2002 | 01:42 AM
polymath's Avatar
Default Re: TODA cams (spoonedcivicG6)
I ran them in my B20vtec...they idled fine once i upped the fuel a little. A set of 97+ Prelude injectors and it idled like stock.
Start playing with the camsprockets and you'll need to do some fuel tuning to keep it running at idle.
Old Nov 3, 2002 | 10:03 AM
Vic's Avatar
Vic
Default Re: TODA cams (Coyote2000cc)
and a good timing belt cauze does are VERRY hard on it !
Old Nov 3, 2002 | 12:07 PM
bhive9024's Avatar
Default Re: TODA cams (Vic)
in reference to the timing belt issue I have heard from a current user on G2IC.com that the OEM timing belt does not work 100% compatibility wise with toda cams- either gonna be a little loose(noisy) or a little tight(premature wear) Purchasing the timing belt made by TODA would be a wise choice if you ended up purchasing their cams. Also, it is highly recommended by almost everyone to follow the valvetrain guidelines that TODA gives in order to use their camshafts. If you dont have the green for the entire setup, either choose something cheaper or keep saving
Old Nov 3, 2002 | 02:14 PM
b19coupe's Avatar
Default Re: TODA cams (bhive9024)
You can also use the Power Enterprise timing belt, a little cheaper than the Toda one, and I have heard that the Toda belt is actually made by P.E.
BlUeHoOdCiViC99
16
Dec 20, 2005 12:11 AM
chet
Feb 8, 2004 02:47 PM
cvclover
13
Nov 3, 2003 11:37 AM
Carnage24
Jan 2, 2003 02:12 PM
JurakS
Aug 20, 2002 07:46 PM
