big throttle bodies...
Old Nov 6, 2002 | 07:06 PM
98DC2's Avatar
Default big throttle bodies...
just wanted to know who out there is using a 70mm throttle body on their NA DOHC vtec & how they like it. did anyone have any problem adjusting idle or tps position?
i just recently purchased a 70mm from erick's racing. it seems to work well, especially w/ skunk2 itm. i just want to know are there disadvantanges of running such a large tb, even w/ right fuel intake amount?
[Modified by 98DC2, 8:12 PM 11/6/2002]
Old Nov 6, 2002 | 07:26 PM
98DC2's Avatar
Default Re: big throttle bodies... (98DC2)
Old Nov 6, 2002 | 07:33 PM
BudaKai's Avatar
You might runn lean if everything is worked over ie. Porting the head and mani. . however if it's not you would get a greater effect with higher compression.
Old Nov 6, 2002 | 07:43 PM
98DC2's Avatar
Default Re: big throttle bodies... (tzsir)
currently, i'm slightly running lean. not too much or even enough to make a difference yet. i checked my plugs last saturday. i do plan to port the head & manifold eventaully.
Old Nov 7, 2002 | 12:50 PM
QCKGSR's Avatar
How much air is going throught he motor and what are the mods just seeing if you even require a larger thrl body. because a larger thrl body can fool you into thinking you have more power, because it acts like your smaller body at a less angle . meanig you only have to open the body a smaller amt. to get the same effect. thus giving you the effect of a fasteeer car because you didnt have to push down as far. get it!!!
Old Nov 8, 2002 | 03:04 PM
98DC2's Avatar
Default Re: big throttle bodies... (QCKGSR)
just a cold air intake for a type r are my only air mods, but i plan to build block & head eventually. i know in the future a tb will help for sure, but as of now, w/ out itm ported to match 70mm, i don't expect to feel significant hp gains. i'm just shooting for better air flow & throttle response.
DelSolMarine
Jan 17, 2011 02:16 PM
slide inside
Oct 21, 2009 01:15 AM
1990_integra_DA9
Feb 22, 2009 09:57 AM
g0tgot
Aug 26, 2007 04:57 AM
turbopanda
Dec 8, 2002 08:55 PM
