Mugen ValveSprings
Old Nov 3, 2002 | 10:43 AM
Engo's Avatar
Default Mugen ValveSprings
hi, can anyone tell me the mugen valvaspring specs? i mean max lift ecc ecc??
will this spring be fine with stage2 skunk2 or stage2 toda or stage2 jun???
thx for helping, i'm really confused ...
Old Nov 3, 2002 | 12:03 PM
bhive9024's Avatar
Default Re: Mugen ValveSprings (Engo)
you might wanna give http://www.kingmotorsports.com an email just to make sure you are getting the correct information. I'm sure someone could spit out specs but unless its from a schematics sheet that mugen has put out, it is all second hand (miss)information
Old Nov 3, 2002 | 03:14 PM
Rob Dizzle's Avatar
Default Re: Mugen ValveSprings (bhive9024)
they are the same as the 98+ itr valve springs
EP did a test and they worked out to be the same springs
they only offer an advantage over 96 itr valve springs.
look into getting portflow or hondasaver has some nice springs
or you could run the skunk2's since that is the same manufacturer as your cams...
HONDASAVER
Springs
HondaSaver B-Series Vtec springs.
Here are the specs:
Material: Chrome-Vanadium Alloy Steel.
Design: Linear Rate, High Lift Capacity, Self-Dampening Interfence with Inner Spring.
Prep: Shot-Peened and Heat Set for maxium durability
Pressure Installed: 80lbs at 1.320" - Good for keeping valves from being blown off their seats in FI apps.
Pressure 12.5mm: 265lbs at 12.5mm lift. Plenty of pressure to track the most aggressive cams like my cams.
Coil Bind: At 13mm lift as measured with both top and bottom retainers installed. Inner spring binds at 13mm lift although Outer spring can handle up to 14.5mm lift if used by itself.
Price: $175 shipped. GUARANTEED FOR LIFE against breakage and loss of pressure.
Old Nov 4, 2002 | 11:00 AM
Engo's Avatar
Default Re: Mugen ValveSprings (Bob-DC2)
thx for helping...
at the end it's better that i'll waste my Mugen Springs?
THX again
earfejj
Northwest (Sales)
Jul 25, 2011 06:17 PM
ej_b16a
May 11, 2007 11:11 AM
MattY81
Jun 29, 2003 11:29 PM
paulITR
Mar 10, 2003 11:55 PM
