Automatic axles & Manual axles...
Can the axles from a automatic B-series tranny be compatible with the manual B-series hydralic tranny? In other words, will the axles fit? Any info would be greatly appreciated.
[Modified by DarkSol97, 10:43 AM 11/5/2002]
[Modified by DarkSol97, 10:08 AM 11/10/2002]
:::Bump:: It would be nice if I didn't have to buy the outter axles, I want more feedbacks on this...
So what your sayin is if swapping from auto - > manual you ONLY need the midshaft.... NOT left and right axles?
My car is a 99, the ls tranny I got is a 96
The outer axles will fit just fine but the mid shaft (that bolts to the back of the block) will not.
Mike
Mike
I did an auto -> manual swap, and the outer axels are the same. Like was said, you only need to get the center half-shaft to fit your new transmission.
