HELP please!! car won't start! read more-------->
Old Nov 2, 2002 | 09:14 AM
one.EG6's Avatar
Default HELP please!! car won't start! read more-------->
Ok, I posted in the EG forum, but figured I might as well post here as well.
https://honda-tech.com/zerothread?id=320609
So the whole story is in there, but here is a rundown.
After changing my girl's clutch in her 95 LS her car won't start. I took off the distributor, and starter during the process, and I feel it has to be in that somehow. The motor is turning over, and sounds like it wants to start, it just doesn't. We are getting spark, fuel, and the motor is turning.
WTF could this be? If the starter was bad the motor wouldn't turn, correct? if the Dist. was bad we shouldn't get a spark, right?
please help!!!!
THANKS!
[Modified by one.EG6, 3:06 AM 11/4/2002]
Old Nov 2, 2002 | 09:43 AM
Chiovnidca's Avatar
Default Re: HELP please!! car won't start! read more--------> (one.EG6)
Is it flooded? Try holding the gas pedal to the floor to see if it will start.
Old Nov 2, 2002 | 10:23 AM
one.EG6's Avatar
Default Re: HELP please!! car won't start! read more--------> (Chiovnidca)
flodded?
we took out the plugs and let it sit for a little while in case it was flooded. Same result.
Old Nov 2, 2002 | 11:30 AM
Chiovnidca's Avatar
Were they soaked with gas?
Old Nov 2, 2002 | 11:37 AM
one.EG6's Avatar
they had some gas, so we let them sit and evaporate.
Old Nov 2, 2002 | 12:16 PM
Chiovnidca's Avatar
Try holding the gas to the floor while you try to start it.
Old Nov 3, 2002 | 11:33 AM
one.EG6's Avatar
I'll try this when I go to the car today... but, what would this do?
Old Nov 3, 2002 | 01:13 PM
Chiovnidca's Avatar
It's a way to start a flooded engine. When the gas pedal is held to the floor while cranking, the ECU wont energize the injectors. So your not adding anymore gas.
Old Nov 3, 2002 | 06:06 PM
one.EG6's Avatar
well, tomorrow is my last chance to get this thing going... then her mom is gonna have it towed to a mechanic. So, I'm gonna do everything possible to try to get it started... change batteries, unbolt/rebolt starter, etc....
any last advice, tips, or things to check before I get into this?
thanks.. I'll let you know what happens.
Old Nov 3, 2002 | 06:49 PM
PnX-R's Avatar
Hmm... So the Starter is cranking huh?.. Is it cranking at a normal rate??.. The Spark Plugs are wet??.. Whenever I run into wet Spark Plugs, I turn on the Propane Stove and burn all the Gasoline off of them. Once that's done, they work fine..
But other than that.. I'm sorry.. I just can't remember how to diagnose the Distributor along with the Starting Circuit.. But one thing I do know is that one of the wires going to the Distributor should have at least 9.6V at cranking. If not, the Ignition System won't have enough voltage to start up the engine..
Old Nov 3, 2002 | 09:59 PM
CivicEx95's Avatar
how do you know you're getting spark? I've done it twice before, but I've left the little black clip that goes to the starter unhooked and was confused to. Check that if you havent already. Other than that, I dunno if you say the car is getting air, fuel and spark
Old Nov 3, 2002 | 10:38 PM
one.EG6's Avatar
Default Re: HELP please!! car won't start! read more--------> (CivicEx95)
I know I'm getting spark cause we took out a wire and plug, and sparked it between the wire and valve cover bolt.
Old Nov 4, 2002 | 01:47 PM
one.EG6's Avatar
ok, I don't know...
now, I think I lined up the crank pulley right to TDC, and when I looked at the rotor it looked like it was pointing at #3... but we put the belt on right the other night... what could be going on?
it cranks over like a champ..
thanks.
Old Nov 4, 2002 | 02:00 PM
Chiovnidca's Avatar
So you did more than just a clutch, huh? Have you checked your cam timing?
Old Nov 4, 2002 | 04:04 PM
one.EG6's Avatar
well, thats the thing.... when the dist. was put back on wrong it cause the timing belt to jump 2 teeth... so we fixed that.
argh!?!?!??! now what?
Old Nov 4, 2002 | 05:29 PM
Chiovnidca's Avatar
A distributor isn't likely to cause the t-belt to jump time. I would double check the cam timing. Do you have the right distributor on it? With the #1 cylinder on TDC, the rotor should point to #1 or #4. Are the plug wires on right? The firing order is 1342.
Old Nov 4, 2002 | 06:39 PM
bullock's Avatar
sounds like you have a timing problem. Your not putting something back right. good luck.
Old Nov 4, 2002 | 08:12 PM
one.EG6's Avatar
Default Re: HELP please!! car won't start! read more--------> (bullock)
thanks for the help guys.. it's too cold outside to do anything more, so I guess I'm done.. a mechanic is going to look at it tomorrow..I know it's just the timing.. somwhere, but it all seemed to line up right.
Thanks.
mister.wong
Sep 13, 2008 04:45 PM
hondaboy4life
May 8, 2006 06:44 AM
Bartman201
32
Oct 23, 2005 06:03 PM
same ol' civic
Jun 5, 2005 07:29 AM
DizDitto
16
Oct 9, 2003 10:21 PM
