cold cranking amps
Old Nov 6, 2002 | 04:09 PM
B18C-RnVA's Avatar
New User
Default cold cranking amps
im in virginia beach and its starting to get pretty cold here...ive been having problems with my car cutting on...its taking longer than usual...what you be signs of the battery not having enough cold cranking amps and how much should i have ...right now the battery i have has about 450cold cranking amps..
Old Nov 6, 2002 | 04:11 PM
Jared's Avatar
Default Re: cold cranking amps (B18C-RnVA)
450 should be ample to get a honda started, your battery may be weak or have a dead cell.
Old Nov 6, 2002 | 04:25 PM
B18C-RnVA's Avatar
New User
Default Re: cold cranking amps (Jared)
well maybe thats not the problem....when i turn the car on...its trying to turn over..but then like in the morning when i first start it...it wont even do that..i can hear the fuel priming, i wonder is it the spark..any suggestions??
Old Nov 7, 2002 | 04:44 PM
PnX-R's Avatar
You pretty much answered your own question.. Yes, I believe the problem is your BAttery..
If you've got a TEg, it needs at least a 410 CCA BAttery.. I bought a 490 CCA just to be safe..
But unlike the other dude, I don't think you've got a Dead Cell in your Battery. You might have a Shorted Cell because Batteries don't have Dead Cells.. Because how can it be dead?.. It was never alive..
But I doubt it's a Shorted Cell.. But if want to test it.. Take your Trusty Multimeter and get a Voltage REading from the Battery.. But before doing so.. Make sure that it is fully charged and that you've gotten rid of the Surface Charge on it. To get rid of the Surface Charge, turn off the Engine and turn on your headlights for about one minute and then shut them off and wait another minute.. Now check the Voltage at the Battery. If you've got something like 12.4V to 12.6V, then you don't have a Shorted Cell.. But if you got a reading like 10V or so, then you've got a Shorted Cell, not a Dead Cell..
But what I think you should do is take your car in to a shop and have them do a Starter Draw Test and a Load Test on your Battery. Your Battery should be able to put out at least twice the Starter Draw. Because you see, at Zero degrees the Starter will draw 200% of the Starter Draw.. And if your Battery can't handle that high of a load. Then it's junk...
But that's jut me though.. Do whatever you want..
love_my_ekcoupe
Jan 26, 2010 08:20 PM
tlsole
Jan 14, 2010 07:35 AM
Ruben19
11
Sep 11, 2008 07:12 PM
speedracer33
May 2, 2005 08:57 AM
