new rear brake pad problems.
Old Nov 6, 2002 | 08:27 PM
-Racer X-
Guest
Posts: n/a
Default new rear brake pad problems.
https://honda-tech.com/zerothread?id=327259
if you can help there that would be great
Old Nov 7, 2002 | 01:52 AM
-Racer X-
Guest
Posts: n/a
Default Re: new rear brake pad problems. (-Racer X-)
anyone?
Old Nov 7, 2002 | 05:03 AM
Mover's Avatar
There is a break-in procedure for new pads. The piston will pop out on its own.
Old Nov 7, 2002 | 06:18 AM
RaceTilIDie's Avatar
Default Re: new rear brake pad problems. (Mover)
Sounds like you need to bleed your brakes.
Old Nov 7, 2002 | 07:13 AM
CXHatchback's Avatar
Default Re: new rear brake pad problems. (RaceTilIDie)
Werd, and check your fluid/reservoir cap.
Old Nov 7, 2002 | 10:11 AM
-Racer X-
Guest
Posts: n/a
forgot to say i have ABS...and what exactly is the break in prcedure?
Old Nov 7, 2002 | 11:00 AM
Mover's Avatar
Email AEM and ask them if their pads need to be bedded in.
Is a series of stops which is suppose to eliminate green fade.
Half a dozen stops in sequence from medium speed to a full stop in a nutshell
Old Nov 7, 2002 | 11:22 AM
-Racer X-
Guest
Posts: n/a
u dont bleed ABS right? and ive driven on em for a day or so now, so i can guarentee they have been broken in....it all feels a little better..not much tho.
Old Nov 7, 2002 | 12:47 PM
-Racer X-
Guest
Posts: n/a
^^^ BACK UP ^^^
Old Nov 7, 2002 | 12:54 PM
owen_the_soyboy's Avatar
yeah dont worry about ABS, that system is an entirely enclossed, diferent system. the fluids of the brake system are separated.
so just bleed your brake lines.
Old Nov 7, 2002 | 01:08 PM
-Racer X-
Guest
Posts: n/a
Default Re: new rear brake pad problems. (owen_the_soyboy)
hmmm i thought u dont bleed anything whatsoever, and how do you bleed jsut the brake lines?
amej8
Honda Civic (2006 - 2015)
Sep 5, 2012 05:42 PM
trickster kid
Jun 27, 2009 10:43 AM
Prudz_lude
Apr 10, 2007 01:47 PM
