Beep Beep, I can't sleep
Guest
Posts: n/a
Anyone ever experience your acessory bell/beep going off when powering down the road? Intermitent, and only does it once, maybe two or three beeps in a row then stops, then a minute or two later it does it again, then it won't do it for 15 minutes???? Car never stops running or stutters???? Seat belt malfunction? Ignition about to trun off? No check engine lite...Any help would be appreciated.
Peace
Schu
Peace
Schu
check your fuse they may be short. Once i had a shorted fuse for the interior lamp and the bell thing would go off when the key wasn't in the ignition. I had the blinker come ion when i stepped on the brakes. I also had the warning lights about the door and trunk being ajar moving from door to trunk.
Guest
Posts: n/a
Could be a Door sensor for sure, any ideas on how to check it? It is the same alarm that goes off when you unbuckle your shoulder restrant?????????????????????????????????????????? ????????????????????
Peace
Schu
Peace
Schu
Strikerrr
Aug 22, 2005 10:09 PM
