gsr tranny problems
Old Nov 4, 2002 | 05:14 PM
Malachi's Avatar
Default gsr tranny problems
im debating what to do with my tansmission. something is messed up with 2nd gear and 3rd if i shift at high rpms. 2nd gear grinds almost all the time unless give it a lot of time going from 1st to 2nd. weird thing is it shifts perfectly first thing in the morning, or after its sat for a long time. does anyone have any ideas for what it could be? i dont know if i should look into having a friend rebuild it, he just did his saab tranny. or just go to a u-pull yard and try to find another used b tranny. any ideas?
Old Nov 4, 2002 | 05:47 PM
3rdGteg's Avatar
Default Re: gsr tranny problems (Malachi)
synchros
Old Nov 4, 2002 | 05:51 PM
Malachi's Avatar
Default Re: gsr tranny problems (3rdGteg)
rings or gears?
Old Nov 4, 2002 | 07:39 PM
GS-Rcivic's Avatar
i have the same problem with my tranny. Best way to go is to rebuilt. Im geting mine done for $300 plus what ever parts i need, which i dont know how much its gonna cost. Anybody have any prices for synchros ??
Old Nov 5, 2002 | 12:38 AM
eg_nezay's Avatar
Have checked your clutch? It could be your clutch that makes it hard to go in gear when its HOT. In the mornings its cold so no promblems right?
Old Nov 5, 2002 | 12:40 AM
ninesecrx's Avatar
Default Re: gsr tranny problems (GS-Rcivic)
Haha...if your paying 300 plus parts, the shops gonna charge you 200 bucks per gear to fix. U might end up with a costly trany. Id look for a cheaper place to build your trany. Where are you located?
Old Nov 5, 2002 | 04:47 AM
Malachi's Avatar
Default Re: gsr tranny problems (eg_nezay)
yeah, but its only 2nd gear. and the disc only has 1000 or so miles on it.
Old Nov 5, 2002 | 10:23 AM
mechanized's Avatar
Sounds like your clutch is shot......or ispect your clutch master cylinder for leaks& pedal play............
Old Nov 5, 2002 | 06:22 PM
Malachi's Avatar
Default Re: gsr tranny problems (mechanized)
you really think this could just be the clutch? man, i would be relieved if the tranny didnt need rebuilding.
Old Nov 7, 2002 | 08:12 AM
Malachi's Avatar
no leaks, anyone else think it could be the clutch? up
Old Nov 7, 2002 | 08:25 AM
Dokta's Avatar
Definately synchros. Ive gone through this more times than I can count. Best thing to do is replace the tranny fluid more often. Only use honda or red line MTF. Then double clutch and/or rev match every shift. It will make you a better driver. I have a 93 Si beater that has had so much abuse the synchros on 2nd, 3rd, and 5th are completely gone, 4th gear is going down, and the 3rd/4th and 5th/rev shift forks are broken. Noone else I know can drive this car, but when I drive it I very rarely get a grind. The only time I ever use my clutch is when I first take off in first or once in while when I'm down shifting.
Or you could do it the right way and rebuilt it yourself, or pay someone 500 to 1500 to fix it.
[Modified by Dokta, 5:27 PM 11/7/2002]
Old Nov 7, 2002 | 08:34 AM
Malachi's Avatar
Default Re: gsr tranny problems (Dokta)
well ive got the friend who could do it for me if i get him the parts. i'll probably go that way, he may not even charge me. im not sure, he just likes working on this stuff and i dont want to tear into this project.
jordan_rael_420
Oct 18, 2010 04:57 PM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
epoxy
Jan 7, 2004 12:02 PM
ken
Nov 26, 2002 04:18 PM
Fr0m4311
Apr 7, 2002 09:31 PM
