Whats the compression ratio for this setup!!
Old Nov 4, 2002 | 07:31 AM
HybriDNA's Avatar
Default Whats the compression ratio for this setup!!
Hey tech's i need help. I am going to buy a block from my friend and this block is a 95 b18b with b16a pr3 pistons in it on ls rods and i need to know what the compression ratio would be if i had a 95 ls head on it. thanks in advance!
Old Nov 4, 2002 | 08:46 AM
QWKPHKR's Avatar
Default Re: Whats the compression ratio for this setup!! (Project_Rex)
The approximate compression for this setup would be around 10.8 to 1.
Pete
Old Nov 5, 2002 | 06:30 PM
MisterB's Avatar
Default Re: Whats the compression ratio for this setup!! (QWKPHKR)
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Nov 5, 2002 | 07:52 PM
HybriDNA's Avatar
Default Re: Whats the compression ratio for this setup!! (cl4show)
badass! Never saw that site! thanks.. helps a bunch!
Old Nov 7, 2002 | 01:12 PM
QCKGSR's Avatar
aprx. 11.1 :1 considering you piston to deck is .020 and your using stock head gasket also that is with a stock 45cc chamber and 89mm stroke hope it helped you out
Old Nov 7, 2002 | 01:18 PM
HybriDNA's Avatar
Default Re: Whats the compression ratio for this setup!! (QCKGSR)
thanks for the info you all are great! Would i HAVE to Upgrade my Oil pump to a b16a oil pump if i add a Type R manifold with TB and crower stage 2 cams with springs because i want to rev safely to 7,800rpm???
rudebwoy
Jul 16, 2006 03:32 AM
lv2exl8
Jun 27, 2006 09:03 PM
lv2exl8
Jun 24, 2006 09:57 AM
super_slow
Feb 19, 2004 01:52 PM
94dxt
Dec 10, 2003 11:10 PM
