Misfire at high revs???
Old Nov 6, 2002 | 11:39 PM
AussieK24's Avatar
Default Misfire at high revs???
Ran my car down the quarter last night. It developed a misfire at the top of 3rd and 4th. I have a standard B16a1 with extractors, 2 1/2 mandrel system and a CAI. I only have a motorcycle battery in the car ATM. I pulled the plugs when I got home and they looked lean but I don't know if that is from racing or the drive home.
Q: Will the small battery cause the miss?
Q2: It shouldn't be running lean with these minimal mods, Should it?
The symptoms are of a fuel system inadequecy (sp) but I have a HUGE fuel system. Only prob is the only FPG I'ev got is under the bonnet.
PLEASE HELP!!!!!!!!1
Old Nov 7, 2002 | 12:18 AM
Dancing is Forbidden's Avatar
Default Re: Misfire at high revs??? (b16a4me)
Sounds like you hit the rev limiter.
Old Nov 7, 2002 | 12:34 AM
AussieK24's Avatar
Default Re: Misfire at high revs??? (EF9_SiR)
Nah I know what that's like tho hehehe. It kept accelerating and the mis was from about 6000 to 8000 rpm
Old Nov 7, 2002 | 02:14 AM
Metal_SOL's Avatar
i have the same problem too, any one knows?
Old Nov 7, 2002 | 04:25 AM
ananh's Avatar
Default Re: Misfire at high revs??? (power_civic)
change your plugs if you have iridiums. they misfire
Old Nov 7, 2002 | 05:28 AM
Lord Quaalard's Avatar
Default Re: Misfire at high revs??? (ananh)
You could try MSD Ignition as well.
Old Nov 7, 2002 | 06:04 AM
RaceTilIDie's Avatar
Default Re: Misfire at high revs??? (MrDyrten)
First thing I would check is your timing, and advance mechanism. Even if your timing is set right at idle, but it advances too much(or too little) at higher revs it can misfire. Too much advance would also explain the lean condition. You will neeed a timing light w/ advance function to check.
Old Nov 7, 2002 | 09:18 AM
NonovUrbizniz's Avatar
Loved
Default Re: Misfire at high revs??? (RaceTilIDie)
if you have an internal type coil (ie theres only 4 wires coming off your dist. cap you should consider buying a msd modifier cap so you can use an external coil. this will greatly improve spark to the plugs.
Old Nov 7, 2002 | 12:42 PM
QCKGSR's Avatar
Default Re: Misfire at high revs??? (NonovUrbizniz)
First check your voltage from the bat. make sure its at least 12vv because the honda ign, takes alot of voltage to run effectivly. then go on to your plugs and wires make sure its not something stupid first before you pull your hair out trying to diagnos something .
Old Nov 8, 2002 | 12:28 AM
AussieK24's Avatar
Default Re: Misfire at high revs??? (QCKGSR)
Thanx for the replies. I'm going out onto a freeway tonight and try some mods. (fuel prssure, ign advance)
Old Nov 8, 2002 | 01:01 AM
polymath's Avatar
after the simple stuff...
are you getting a CEL? is your tach acting up?
Old Nov 8, 2002 | 01:11 AM
AussieK24's Avatar
Default Re: Misfire at high revs??? (Coyote2000cc)
No CEL codes and I don't have a tacho...
Old Nov 8, 2002 | 01:16 AM
polymath's Avatar
hmmm...in addition to all the afforementioned stuff i would double check all connections in and around the distributor just to be sure.
I've had my ignitor start to misfire on me but not show a CEL until a week or two later.
Old Nov 8, 2002 | 02:21 AM
AussieK24's Avatar
Cool thanx. I'm off to play on the freeway...
Old Nov 8, 2002 | 04:06 AM
AussieK24's Avatar
Well I dropped some timing and took the FP up to 42 psi and went out on the "$1.60 dyno" (otherwise known as the local tollway) and the misfire has gone. WAHOOO!!!
I thought advanced timing would only lead to pinging at low speeds/high loads but ......
Old Nov 8, 2002 | 04:59 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Bad distributor coil.
mobebk
Aug 16, 2006 08:49 PM
fxrob
Dec 28, 2003 08:21 AM
Timmay
Aug 18, 2003 08:43 AM
fEAR9
Dec 15, 2002 06:16 PM
Keyed ITR
Dec 4, 2001 01:49 AM
