what tool besides puller to get off lower control arm to remove CVs
Old Nov 4, 2002 | 07:02 PM
uncleben's Avatar
Default what tool besides puller to get off lower control arm to remove CVs
been to 3 places looking for the right kind of puller described in my helms manual with no luck. any other way to pull apart the lower arm so I can take off the bad CV axles?
Old Nov 4, 2002 | 07:11 PM
bryan305's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (uncleben)
put a couple nuts on the ball joint and just hammer it out.
Old Nov 4, 2002 | 08:13 PM
the DR.'s Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (bryan305)
put the castle nut back on.. then theres a little protrusion(sp) where the ball joint goes through, get a big hammer and beat the crap out of that, also if it doesnt comes out easily, get someone to hold a pry bar and push down the arms whiel you hit it with the hammer, and if that doesnt work you'll probably need an air hammer w/ a picklefork.
Old Nov 4, 2002 | 08:21 PM
uncleben's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (CIVICtypeS)
yup we already did all that too - and it didn't even budge!
heh -holy crap.
maybe i need to find the puller
Old Nov 4, 2002 | 11:11 PM
kinesistech's Avatar
I can pull axles in 7 min. because I dont bother with ball joints. I just pull the bolt that holds the front of the lca to the body the whole knuckle will move out of the way and out comes the axles. Calm down, its ok. A pickle fork will ruin it garunteed.
Old Nov 5, 2002 | 12:32 AM
ninesecrx's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (kinesistech)
find a good puller...its well worth what ever u have to pay. Also you can take a blow torch and heat the arm up and it will help get the ball joint out.
Old Nov 5, 2002 | 04:30 AM
uncleben's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (ninesecrx)
HT rocks... you guys rock - thanks for all the tips. i'll let you know what i do
Old Nov 5, 2002 | 06:14 AM
Chrislow's Avatar
Do what kinesistech said, it's a lot easier and you won't screw anything up. A lot less of a headache.
Old Nov 5, 2002 | 08:56 AM
uncleben's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (Chrislow)
thanks again!
Old Nov 5, 2002 | 10:39 AM
rastropovitch
Guest
Posts: n/a
Whats an "Ica"?????????????? I'd like to be able to pull mine in minutes to!
Schu
Old Nov 5, 2002 | 10:57 AM
Prod's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (MSchu)
Schu
lca - lower control arm was my interpretation
Old Nov 5, 2002 | 11:57 AM
sackdz's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (Prod)
Pitman arm puller. ~$15 at Autozone. Or just put a wrench handle between the knuckle and lca and compress the suspension with a jack.
http://www.autozone.com/servlet/UiBr...ie_rod_end.jsp
or larger...
http://www.autozone.com/servlet/UiBr...pitman_arm.jsp
Old Nov 5, 2002 | 12:57 PM
uncleben's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (sackdz)
this was our next bet actually... i'll try the other suggested options if it doesn't work as well.
thanks again guys...
Old Nov 5, 2002 | 07:47 PM
StorminMatt's Avatar
I tries this once and ended up with a broken puller rather than a separated ball joint. Honestly, the best approach if you don't have a puller is to remove the lower control arm.
Old Nov 5, 2002 | 09:13 PM
Nameless RB26's Avatar
Default Re: what tool besides puller to get off lower control arm to remove CVs (StorminMatt)
I worked around mine. I unbolted the whole arm and worked the axle out under the fork.
I'm suprised no one has ever done that.. EASY as ****.
Old Nov 5, 2002 | 09:39 PM
uncleben's Avatar
Well the pitman arm puller didn't hold on, so we took off the lower control arms. It looked like just unbolting the arm (from the chasis) wouldn't be enough so we went ahead and unbolted the radius arm and sway bar from the LCA first (not much more work) and then put the new axles in. All good now!
thanks all!
Old Nov 5, 2002 | 10:18 PM
Yeah, I wasn't sure what model you had but the radius arms would also need to move if it has them.
Old Nov 6, 2002 | 05:33 AM
92sleepR's Avatar
New User
Here is a trick I learned on H-Tech a few years ago. I'm surprised that on one posted it.
thread the castle nut (or any flange nut) on to the end of the ball joint stud enough to cover the end with the holes in it (get it down to the full threads). Place a couple of sturdy concrete blocks under the ball joint, place a 15 mm socket over the nut and then carefully lower the car untill the ball joint stud/socket is resting on the blocks. Let the weight of the car work for you. If the ball joint doesn't pop free just from that, a few shap whacks with a 5lb. sledge hammer on the side of the lca around the ball joint should do the trick.
This is the only method I ever use now and it works every time.
Mike
tree fingers
Feb 18, 2008 10:41 PM
94vtirozguy
Suspension & Brakes
Apr 3, 2006 08:32 PM
david90
Apr 3, 2004 08:28 PM
ScottEK
17
Sep 21, 2002 06:23 PM
illusion
Sep 10, 2002 05:13 PM
