Engine builders I need camshaft help !
HELP!! I have just gotten i set of cams (used) and one has a knick in it large enough to catch a nail in. Can it be smoothed off with an emory cloth or sandpaper or is it now unusable ?
as long as its still smooth on the outside surface it shouldnt affect anything..I dont know if i would trust any machine shop to screw with those cams.. Ive heard horror stories.
I would rub it smooth with a super fine piece of emerycloth. Remove as little material as possible. I wouldnt bother with a machine shop.
Just smooth the edges and run it. Check it again in a month and see if anything is changing. You are probably ok.
MikeD21
Engine Machining & Assembly
Nov 22, 2018 06:06 PM
Papa_Smurf_21
Feb 22, 2005 05:27 AM
