crvtec bad r/s?
Old Nov 5, 2002 | 11:57 AM
91hatchcivic's Avatar
Default crvtec bad r/s?
i have heard he lsvtec has a bad r/s , and can warp the (cylinder?) walls and can snap rods is reved over 6250k. is there any of these problems with the crvtec??
Old Nov 5, 2002 | 01:02 PM
Jeff C's Avatar
Default Re: crvtec bad r/s? (91hatchcivic)
The r/s is the same for both setups.
My crvtec just hit 4k miles and has seen over 8k rpms many times.
This has been covered a lot.
Old Nov 5, 2002 | 01:41 PM
Katman's Avatar
well, yes the B20's & LS (which are essentially the same engine), do have a rod ratio in comparison to a B16A engine (which is near perfect rod ratio). People don't care though....they want the torque.
But LS and/or B20vtec engines in general, aren't suppose to be rev'd too high because of the powerband. Generally, when you go up in liters the redline drops and this is because you're trading horsepower for more torque. So, a sufficient redline (usually around 8500rpm max) should be respected, in order to keep engine life longevity.
[Modified by Katman, 2:41 PM 11/5/2002]
redlseg
18
Jun 27, 2005 06:55 AM
SPOOLINmatt
Apr 8, 2005 09:18 AM
HeikDiesel
Feb 19, 2005 07:58 PM
Screamer
119
May 6, 2004 07:20 AM
