timing problem after cam install?
Old Nov 5, 2002 | 07:15 PM
1.7na's Avatar
Default timing problem after cam install?
I just finished installing my skunk2 stage 1 in my car. Checked my timing and it was at about 8 so I tried to advance it. I can't seem to get it back to the stock
setting, 16. The max I can get is maybe about 10. My cam gears line up and #1 was at TDC using the crank mark. Can this be cause because the TDC mark on the crank is not accurate? Car runs strong so I don't think it's off a tooth. I just can't seem to get a accurate reading on my timing anymore. Any suggestions??
Couldn't find much about this with a serach.
1.7NA
Old Nov 5, 2002 | 08:24 PM
the DR.'s Avatar
Default Re: timing problem after cam install? (1.7na)
The TDC mark on the crank should be 100% accurate.. your cam gear might be off one tooth..
Old Nov 5, 2002 | 09:31 PM
tinkerbell's Avatar
do you need to jump a service connector on your ecu when setting the timing like on the 1st get set-ups?
(i dojnt know if this is your problem though...)
t..
Old Nov 5, 2002 | 09:36 PM
3rdGteg's Avatar
Default Re: timing problem after cam install? (CIVICtypeS)
turn it to tdc on the crank white mark and see if those cam gear marks line up evenly.
Old Nov 5, 2002 | 09:37 PM
3rdGteg's Avatar
Default Re: timing problem after cam install? (tinkerbell)
t..
Hey Tinkerbell, Why do we have to do that anyway? I see no difference when I do it with the service connector jumped
Old Nov 6, 2002 | 07:43 AM
1.7na's Avatar
Default Re: timing problem after cam install? (3rdGteg)
Yes, I rotated the crank and confirmed that everything lined up at TDC (white mark on the pointer) before I put everything back together. The cam gears marks lined up perfectly. I read that the skunk2 (stage 1) ping holes do not line up correct when at TDC? Can anybody confirm this? The pin holes lined up perfectly for me. Oh, and yes I did jump the connector when checking my timing.
thanks
1.7NA
civiccoupe94
Jan 11, 2008 07:08 AM
gsrpedro
Oct 17, 2007 08:56 AM
Project_CD5
Jul 25, 2007 03:20 AM
I8ayellowcrayon
Dec 27, 2004 07:51 PM
Tommy_Gunns
Aug 23, 2002 03:07 PM
