The new CR-Vtec???????
Old Nov 3, 2002 | 07:14 PM
Samsonite's Avatar
Default The new CR-Vtec???????
This idea may have been talked about before but i did a search and found nothing.
I just got to thinking the new crv motor is a 2.4l k series engine. The RSX type S is a K series engine. So here is what i am getting at. Could there be a new Frankenstien swap even better than the powerful b20vtec's? I know the k24 is a i-vtec just like the k20a but dont know much about the head. But in theory you should be able to take a k24 block and attach a k20a2 head onto it making a pretty powerful combination. Compression would probably have to raised from the crv's 9.6:1 to make some good power but it should work. Anyone else thougth about this? I know it would eb really expensive to do right now but i think this could be the future of all motor honda's
Old Nov 3, 2002 | 07:22 PM
Kamin's Avatar
Default Re: The new CR-Vtec??????? (Samsonite)
Hasport in phoenix is already working on this
i havent heard an update in a while.
Old Nov 3, 2002 | 07:24 PM
Chiovnidca's Avatar
I just got to thinking the new crv motor is a 2.4l k series engine. The RSX type S is a K series engine. pretty powerful combination.
Also the new Civic Si is a k20. And the k24s in the new Accords run very strong.
Old Nov 3, 2002 | 08:48 PM
90H22's Avatar
Default Re: The new CR-Vtec??????? (Chiovnidca)
Isn't the K24 in the Accord from the CRV? Sounds like a good plan, but I wonder if they have to run new oil lines and passages like the B20 VTEC. That's the part where most CRVtecs go wrong.
Old Nov 3, 2002 | 09:03 PM
Samsonite's Avatar
Default Re: The new CR-Vtec??????? (90H22)
i doubt it would be a difficult as a b20vtec b/c the k24 is already a i-vtec engine, like i said i don't know much about the head on that engine it may be good how it is, but i would think a k20a or a2 head would swap on fine. the head itself my be the same, if so you could just swap some k20a or a2 internals in to the k24 head(cams valves, springs ect).
Old Nov 3, 2002 | 09:09 PM
90H22's Avatar
Ahhh, I completely bypassed the whole "it's already i-vtec thing." Hmmm . . . that will make it a lot easier.
Old Nov 3, 2002 | 11:01 PM
kinesistech's Avatar
Old idea.
Old Nov 3, 2002 | 11:24 PM
tinkerbell's Avatar
correction, it is an oil line (singular),
and no 'new' oil passages are run, one is simply blocked off.
you must be into H22s?
t..
Old Nov 4, 2002 | 12:50 AM
90H22's Avatar
Default Re: The new CR-Vtec??????? (tinkerbell)
The B series is garbage anyways! Gimme my H!
Old Nov 4, 2002 | 03:43 AM
No-Gi's Avatar
from what I read the k24 has a long *** stroke so I am not sure if it would bw wise to just bolt up the head an rev to 8k
Old Nov 4, 2002 | 03:49 AM
Samsonite's Avatar
Default Re: The new CR-Vtec??????? (B16aEK)
same bore longer stroke? or a little more of both? if the bore is the same you could put some rsx type S pistons in. I don't know if anyone is making block internals for the new k motors yet
Old Nov 4, 2002 | 05:24 AM
94CivicSi's Avatar
This is the problem. You'd need a bulletproof and perfectly balanced bottom end before even trying it. Simple head swaps are not an option.
mr_munro
13
Dec 29, 2011 06:51 AM
g0tgot
15
Apr 17, 2009 08:33 PM
1badda
14
Oct 1, 2004 05:18 PM
mr poo
10
May 9, 2002 04:38 PM
rainforest
Nov 21, 2001 05:52 AM
