b16a hatch, axle/clutch install???
Old Nov 4, 2002 | 06:00 PM
stockegsix's Avatar
Default b16a hatch, axle/clutch install???
do i have to remove the driver side axle to install my clutch?
Old Dec 5, 2002 | 11:53 AM
MikeMAN's Avatar
Default Re: b16a hatch, axle/clutch install??? (zzZZzzleeperCX)
i think it was the passenger side, but don't quote me on that..
mike
Old Dec 5, 2002 | 12:57 PM
salbaje's Avatar
you will need to remove the halfshaft and passenger side axle
Old Dec 5, 2002 | 04:44 PM
ill phil's Avatar
Default Re: b16a hatch, axle/clutch install??? (salbaje)
Just unbolt the halfshaft and pull the driver side hub from the LCA and pull it out a little to get the driver side axle and half shaft out of the way. Well more out of the way than leaving it in.
Old Dec 6, 2002 | 10:04 AM
iwhichisme's Avatar
you dont have to remove the driver side axle,but you do need to unbolt the half shaft (sort of laying it to the side), as well as remove the passenger side axle. YOu might as well drain the tranny and refill with new fluid. Either 10w30 or Hond MTF will work. Id go wiht the Honda MTF, because it is supposed to be better quality, and if anything were to leak, you would know wether or not it was the tranny or the motor becasue Honda MTF is red.
jmurphy
17
Apr 5, 2011 01:19 PM
jdm_racer831
Jul 10, 2008 06:38 PM
WPeters
Apr 30, 2008 07:19 AM
huyvu90
Sep 4, 2004 09:25 AM
