help with factory LSD install on b18c tranny
Old Dec 16, 2001 | 08:38 PM
Markaccord95's Avatar
Default help with factory LSD install on b18c tranny
Help!
I ran into problem today. The LSD doesn't fit into the transmission case. The pictures below show the problem. The fins marked with the arrows in the top picture do not allow clearance for the housing of the LSD marked with the arrow in the bottom picture. The only way I see this LSD going into this transmission is if I grind down the fins, but I want to make sure this is safe and will not affect anything else. thanks
Old Dec 16, 2001 | 09:24 PM
rainforest's Avatar
Default Re: help with factory LSD install on b18c tranny (Markaccord95)
shave down the fins and flush the hell out of it.
Old Dec 16, 2001 | 10:35 PM
samiam's Avatar
Default Re: help with factory LSD install on b18c tranny (rainforest)
what type of lsd does the jdm y-1 have? gear type clutch etc?
Old Dec 17, 2001 | 10:43 AM
VTEC4GS's Avatar
you're suppose to shim where you have the red "B" written. Pop out tapered carrier bearing sleeve shim then re insert sleeve. When the diff fits, the top of the ring gear should be almost flat with the edge of the bottom case. To figur eout the shim size, stick diff in then measure from top of ring gear to top of lower case edge.
Greg
Old Aug 1, 2003 | 05:00 PM
gsxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">shave down the fins and flush the hell out of it.</TD></TR></TABLE>
i thought you could just pop in an itr lsd into a b18c1 w.o. doing much modification?
Old Nov 21, 2003 | 08:47 AM
google's Avatar
Default Re: help with factory LSD install on b18c tranny (gsxr)
scammer
docbrown
Transmission & Drivetrain
Jul 31, 2010 01:45 PM
FreaQ
10
Mar 12, 2009 08:34 AM
PrecisionH23a
Apr 29, 2006 09:29 AM
bracket 4 life
Feb 13, 2005 10:05 AM
Evil EG
Sep 12, 2002 10:48 AM
