BMW Valvetronic!?! SCC Article for this month.
Old Dec 26, 2001 | 06:54 AM
Spade's Avatar
Default BMW Valvetronic!?! SCC Article for this month.
Did anyone read it!?! They are going to be removing the Trottle bodies from BMW's. Apparently the valves/cams are so adjustable that it opens valves to the peddle pressure instead of the butterfly in the trottle body!?! Um, can you say Kiss me rear smog!?!
Old Dec 26, 2001 | 07:09 AM
WAFFLES's Avatar
Default Re: BMW Valvetronic!?! SCC Article for this month. (Spade)
I read a little bit about it in a previous C&D issue...pretty cool stuff.
Old Dec 26, 2001 | 03:37 PM
John's Avatar
New User
Default Re: BMW Valvetronic!?! SCC Article for this month. (WAFFLES)
plus BMW isn't far away from putting a non-mechanical valvetrain into production... variable valvetrain compliments of solenoids... yum!
Old Dec 26, 2001 | 11:34 PM
Raymund's Avatar
New User
With all the extra rocker arms and extra weight, i highly doubt that design will ever rev pass 6000rpm. prodution engines at least. Plus that hydraulic lifter is a big no with high rpms. i could be wrong.
Old Dec 27, 2001 | 06:06 AM
Spade's Avatar
Default Re: BMW Valvetronic!?! SCC Article for this month. (Raymund)
I don't know, but at the same time BMW is only releasing it in the 7 series for now and you know those engines don't need to go over 6K to produce power.
HTNoob
Aug 20, 2019 03:42 AM
jiggacivic
Sep 29, 2014 05:00 AM
TrboGzR
44
Apr 3, 2009 02:44 AM
logg_frogg
16
Apr 5, 2008 05:17 PM
Meshmasteryow
Mar 30, 2005 07:57 PM
